wheeldock center stand
Old Feb 5, 2011 | 10:39 AM
cav1429's Avatar
cav1429
Cool wheeldock center stand
just pick one of these up. From Wheeldock its call E-Z center stand . Look like a breeze to hook up anyone have one like this
Old Feb 5, 2011 | 10:54 AM
kyote's Avatar
kyote
piece of cake...only takes about 5 mins...
Old Feb 5, 2011 | 11:04 AM
cruise_carter's Avatar
cruise_carter
Lots of threads on the forum about the EZ-UP, some don't like it but I like mine a lot.
Easy to install and use, works for me.
Old Feb 5, 2011 | 11:09 AM
luisan's Avatar
luisan
Just be careful and avoid tilting the bike while you raise it on the stand,I dropped mine a couple of times,other than that no problems.
Old Feb 5, 2011 | 11:38 AM
socalmoe's Avatar
socalmoe
Default Same here....
I quickly learned to drop my kick stand before attempting to do the center stand. Once you get away from the balance point, down she goes!
Old Feb 5, 2011 | 12:09 PM
'05Train's Avatar
'05Train
Very easy to put on, and thankfully very easy to take back off. I absolutely hated the thing. It took away way too much of the available lean angle.
Old Feb 5, 2011 | 12:36 PM
stupid_rope's Avatar
stupid_rope
I like HDs center stand as far as looks are concerned. how far down does that ezup hang?
EDIT: THanks train, that's what i was afraid of
Old Feb 5, 2011 | 04:29 PM
cav1429's Avatar
cav1429
Thanks, I just installed it yep 5 minutes no problem.Goes up and off real easy More room in the garage now and looks kike i will be able to get that extra gallon of gas in the fuel tank now.
Old Feb 5, 2011 | 04:53 PM
Chaffeekid's Avatar
Chaffeekid
I don't have the easy up, but I have a center stand as you can see from the sig pic.
I use it all the time. Never had a problem, as you can see it goes over center so you have to really rock it to get it off the stand. Never have scraped it on turns, but what do I know, I'm a Geezer driver
Ride Safe road hazards are EVERYWHERE
Old Feb 5, 2011 | 05:45 PM
oldbagr's Avatar
oldbagr
I have the EZ-UP on my Ultra and have never had any problems with it. I use it all the time when on level ground or in the garage. Makes working on the bike a lot easier and, if you put a 1/2" piece of plywood under it you can spin the rear wheel when washing the bike. Best part is that it is a drive-off stand.
