Funny noise while bike is on trickle charger
Old Mar 28, 2019 | 09:49 AM
08-Nightster's Avatar
08-Nightster
Default Funny noise while bike is on trickle charger
I am not sure that my battery is charging. I have been putting it on a trickle charger each night since I got a new battery. The first day I was out riding with the new battery after letting it sit for a few hours it would not start and I had to jump it to get it home.
I am not sure yet if I have a voltage regulator or stater problem. But now it makes this strange noise whenever I have it hooked up to the trickle charger.
Does anyone know what this is?
Fuel injectors?
Thanks
Old Mar 28, 2019 | 11:42 AM
hardheaded's Avatar
hardheaded
What kind of trickle charger ? I had mine on a new style Deltran Battery Tender and i was getting a pulsing buzzing noise back though the alarm siren. It does not do it while using the older tender.
Old Mar 28, 2019 | 11:49 AM
saltlick's Avatar
saltlick
what the hell is that?
Old Mar 28, 2019 | 11:52 AM
08-Nightster
I have a different style charger at home. When I get home I’ll hook it up to that and see if it still making that noise .
btw, when I take it off the trickle charger and start it, then put it back on it stopped making the noise...
Old Mar 28, 2019 | 12:15 PM
08-Nightster
2008 Nightster XL1200N
Old Mar 28, 2019 | 12:40 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Does not look like a trickle charger, looks like a 10 amp fast charger, probably cooked your battery if you left it on and it does not have auto shut-off.
Old Mar 28, 2019 | 01:04 PM
08-Nightster
wrong...
it has 3 different amp settings with the lowest being 2 amps
Old Mar 28, 2019 | 07:17 PM
Ed Ramberger's Avatar
Ed Ramberger
It's probably the IAC motor cycling because the relay got water in it - known issue and a past bulletin. It would kill the battery because the IAC just kept running with the key off due to the relay being shorted.
Can't hear the noise well but from your description I believe that's the direction you should look.
Old Mar 28, 2019 | 09:05 PM
08-Nightster
thanks, will check that
Old Mar 29, 2019 | 12:16 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t just start buying parts...Systematic troubleshooting will find the issue much cheaper than guessing and changing parts.
Perform a parasitic battery drain test.
If it shows excessive battery drain, pull one fuse at a time until you have isolated the affected circuit.
