Don`t just start buying parts...Systematic troubleshooting will find the issue much cheaper than guessing and changing parts.
Perform a parasitic battery drain test.
If it shows excessive battery drain, pull one fuse at a time until you have isolated the affected circuit.
Agree with everything you say. I dont have the money to just go out to start buying parts anyway. I like your idea of pulling the fuses to find the culprit if theres a drain on the battery
