Positioning the Lift on a Road King
Old 12-01-2012, 06:31 PM
CRF's Avatar
CRF
CRF is offline
Default Positioning the Lift on a Road King
Quick question.... I'm using a Sears type 2 rail lift that I've used on my old Dyna. Wanting to put the Road King up on the lift to install a rear lowering kit (LA Choppers). I'm a little worried though cuz theres a cross member under the oil tank that sits a bit lower than the frame rail and the manual says not to put the lift under there but it doesn't seem to want to line up anywhere else..... on the Dyna I had to use these little plastic things that installed on the frame rails but I don't think I need em on the RK.... any suggestions? Pics of where to position the lift rails would be great if anyone has em.....
Thanks!!
Old 12-01-2012, 07:06 PM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
I had the same lift until I got tired of replacing the bottle jack. I forget what one I have now but it is American made. Regardless it works the same other than the one I have now is lower and easier to get under the bike. In any case I never had the issue you are explaining. Just gonna have to figure it out. Sorry but my Road King is an 01 so maybe there is something different.
Old 12-01-2012, 07:23 PM
tccraiger's Avatar
tccraiger
tccraiger is offline
I put the jack rails right in front of the crossmember, is probably not as stable as could be but I have had no problems thus far.
Old 12-01-2012, 07:26 PM
2black1s's Avatar
2black1s
2black1s is offline
I think the caution note in the manual is just that... A caution. Just use a little common sense and you'll be fine.
With a lift like yours, and lift pads that span across the full width of the frame there is no problem with being on the crossmember. Your lift's pads are going to contact the crossmember at the ends and very near where it is welded to the frame rails... That is essentially the same as contacting the frame rail.
Now if you were using some kind of lift that didn't span across the full width of the frame, I could see damaging/bending the crossmember if you tried to lift the bike with a lifting contact point farther from the frame rail and towards the center of the crossmember.
Old 12-01-2012, 08:19 PM
torinoman's Avatar
torinoman
torinoman is offline
I own a js jack.The instructions tell me to place the rear leg in the u channel under the oil tank and make sure that both legs contact both frame rails. So far I've had no problems jacking that way.
By the way you didn't mention the year of your rk, mine is a 03. I don't know if the new wider frames have the same u channel as mine.
Old 12-01-2012, 11:57 PM
CRF's Avatar
CRF
CRF is offline
Mine is a 2011
this is the style of lift I'm using...
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old 12-02-2012, 12:27 AM
2kids3pets's Avatar
2kids3pets
2kids3pets is offline
Originally Posted by CRF
Mine is a 2011
I have the same jack...right up tight to the crossmember and jack away
Old 12-02-2012, 12:43 AM
CRF's Avatar
CRF
CRF is offline
Cool; you look like you're quite far forward with the jack (or is that just the angle of the photo?)... are you in front of the cross member, on it or behind it?
Old 12-02-2012, 01:29 AM
Expat1's Avatar
Expat1
Expat1 is offline
Location: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Do you want to lift the front wheel, both wheels or just the rear?
The answer to the position is in the question
I use a scissor jack because of its small footprint, like this one:
http://www.easternperformance.com/pr...ic-Motorcycles
intrepidxc
Milwaukee Eight (M8)
13
08-24-2017 06:49 PM
mattVA
06-28-2017 12:02 PM
terrysillik
04-24-2012 07:23 AM
motordrum
07-13-2009 09:28 PM
ninetyzero
06-03-2008 09:03 AM
Quick Reply: Positioning the Lift on a Road King
