Amps Rockford Fosgate
Old May 13, 2015 | 06:44 PM
  #81
nevada72's Avatar
nevada72
Originally Posted by Jermell
I am adding an amp. The amp has connectors for out put and input. So I must be missing a step
You are. It's this -
http://www.cyclesounds.com/dsp-line-...ox-harley.html
And while you're at it, just get the grills from them. No hassle install and you can mount the speakers outside the pods.
http://www.cyclesounds.com/metal-spe...15-harley.html
They mount perfectly and look great.
Fwiw, that's what I used and it was a breeze. The sound is 1000% improved. LOUD! I had a friend ask me to turn it down because it was hurting his ears. But with no distortion.
Old May 16, 2015 | 08:28 AM
  #82
bradja's Avatar
bradja
Originally Posted by Bikerscum
Here... it's the white & blue wire....
JK... you don't need to try to tap into the speaker wires at the head unit, tap in at the speaker connectors on the pods. You can buy a wiring harness from Cycle Sounds that will plug right in to the stock connectors if you want to make life easy.
Well, I won't be doing that any time soon.
Old May 16, 2015 | 08:38 AM
  #83
bradja's Avatar
bradja
I know the fairing front needs to come off. Do you need to to this to upgrade a 4 speaker 2014 Limited?
Old Jul 6, 2015 | 08:30 PM
  #84
frashr's Avatar
frashr
2nd Gear
Default Dealer unable to flash radio?
Hi all,
I've read a gazillion threads on amp upgrades and haven't seen anything on this, so "apologies in advance" if any of this has been discussed elsewhere. Here's the thing: on a 2015 Road Glide Special, I recently installed a RF PBR300X2 Amp, Polk Audio MM651's, and NVX-XPLOC2 line converter. The NVX converts high level speaker outputs to low-level RCA, which I preferred to use. I did what I think is a pretty nice installation, 100% soldered connections, power supply direct to battery, ground to bike chassis, remote turn-on wired to cigarette lighter power, etc. The set-up sounds considerably better than the OEM speakers and head unit, however I am having a few issues/concerns:
1. First, when I turn my ignition ON I hear two relatively loud "POPS" from the speakers, a second or two apart, when the amp starts up. Anyone else?
2. Secondly, my dealer was unable to "flash" my head unit - saying that the system is not "recognizing" any amp installations, and backing that up by saying that the HD-MOCO has written increasing sophisticated software into the systems, making it more and more difficult to flash head units with after-market upgrades. Anyone seen THIS?
I have no point of reference as to the potential of this setup (in other words "how good it SHOULD sound") and I am wondering if I am getting what I should out of it since the head unit is not flashed. All indications are that flashing the head unit to remove DSP pre-sets, or using a Magic Box to flatten the signal, are recommended so my concerns on that are:
3. Maybe remove the NVX line inverter, run high level speaker leads directly to the RF PBR300X2 Amp, and see if the head unit "recognizes" an amp installation - so it could be flashed?
4. Or .. Perhaps I could remove the NVX line converter and simply forego a head unit flash by installing a Magic Box? Basic logic tells me the flash is the way to go, rather than working 'backwards' with a Magic Box, but I'm no electrical engineer.
Any direction on this is appreciated, thanks!
Rob
Old Jul 6, 2015 | 09:34 PM
  #85
Scott14SG's Avatar
Scott14SG
Rob
#1- Yes, mine did that as well. I've since upgraded to a PN4.1000D and I can barely hear it now. I'm an amateur compared to some of the guys here so I don't know why it does that.
#2- Your dealer is correct, it will only recognize the Boom amp if installed. However they can flash it to the RF or BT suggested way. My tech took me in the back and I watched him do the flash, click a few buttons and done, takes a minute or two at best. I can't find the document that RF had for the radio flash so Here's something you can print for them (If I remember correctly RF suggested AMP 1-2 off, 8 speakers on); http://www.biketronics.com/content/2...mp%20Flash.pdf
#3-4 I have no idea, maybe haze or Gannicus will chime in. I ran mine with the high level connectors and I have the BT 7.1's in my fairing, the amp was plenty powerful and at 3/4 volume it was loud and clear at 80mph.
Old Jul 7, 2015 | 02:51 PM
  #86
frashr's Avatar
frashr
2nd Gear
Thanks for the input, Scott - I will try a few different things and see if I can flush out some of these issues!
Old Jul 7, 2015 | 07:06 PM
  #87
03Custom883's Avatar
03Custom883
Wonder if the I could use the pbr 300 x2 with my boom audio speakers(just have fronts on my street glide) and the magic box ?
Old Jul 8, 2015 | 07:12 PM
  #88
Scott14SG's Avatar
Scott14SG
Glad to help, I've gotten plenty here myself so it's nice to pass it along.
03Custom883- I'm not sure, but all the time I've spent going over audio threads I think most here would recommend putting in better speakers, the Boom stuff I don't think can handle it.
Old Jul 9, 2015 | 04:40 AM
  #89
03Custom883
I figured that. But since I had them in there thought I would give it a shot
Old Jul 9, 2015 | 09:03 AM
  #90
Sunnyday91360's Avatar
Sunnyday91360
[QUOTE=frashr;14182469...... I did what I think is a pretty nice installation, 100% soldered connections, power supply direct to battery, ground to bike chassis, remote turn-on wired to cigarette lighter power, etc. [/QUOTE]
really don't know if it will make a difference with the popping, but could cause other problems along the way, the Rockford PBR300 install instructions and also an advisory tells you to run ground wire all the way back to the battery, and not to use chassis ground.
