Another hydraulic clutch thread
Old Apr 16, 2023 | 04:00 PM
KrzyCollan's Avatar
KrzyCollan
Default Another hydraulic clutch thread
Hey guys, I have a 2014 street glide, I know there are a lot of hydraulic clutch threads about how they're hard to pull or about how to adjust them. From what I understand, there is no way to adjust them and many ppl have hard to pull clutch levers. And yes, I know there are levers and slave cylinders that can be purchased, but is not the purpose of this thread.
The thing is that I've watched a lot of videos on this subject, where guys who have the same bike as me are installing the new levers. And in their video, BEFORE they even install the new part, every time they pull the clutch lever, it looks like they're able to do it with ease, like no effort at all. And I don't understand why, 'cause mine is not like that, at all, not even close.
For instance, this video, from 3:38 - 3:48 he pulls the clutch the times and just look how easy it is!
https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DiXQVDcCnXrw&ved=2ahUKEwi4l9yXnK_-AhWaHTQIHUELCPkQwqsBegQIDBAE&usg=AOvVaw1-kQbeb6a6JpHotc4mzywr
So, that's what I'm trying to figure out, what these guys have on their bikes that make it so easy for them to pull that clutch in and why mine is so hard. Does it have anything to do with the fluid? Or is it the master or slave cylinder? I know it's not the lever.
Thanks in advance!
Old Apr 16, 2023 | 05:39 PM
Hulkss's Avatar
Hulkss
https://www.google.com/url?sa=t&sour...a6JpHotc4mzywr
Thanks in advance!
Could it be grip strength? I use a grip exerciser set on 90 lbs. The stock lever pull is supposed to be about 15 lbs.
Old Apr 16, 2023 | 05:58 PM
jake24lt's Avatar
jake24lt
Thanks in advance!
Kind of contradicting yourself there. Outside of lightening the clutch springs, changing the slave cylinder is the easiest way to get some lever relief. Fluid is DOT 4. Maybe the guy in the video spends hours in the gym.
Old Apr 16, 2023 | 06:23 PM
Y2K's Avatar
Y2K
Seriously the thing to do is a better slave,I have the Muller in my bike and it's a night and day difference in both ease of pulling the lever and the friction zone not being just on and off like the stock one was.
Get the Muller or Rekluse,either one will be a big improvement.
Old Apr 16, 2023 | 09:18 PM
KrzyCollan's Avatar
KrzyCollan
Yeah, I guess I did lol and maybe he does
Old Apr 16, 2023 | 09:36 PM
KrzyCollan's Avatar
KrzyCollan
I ride at least 3 times a week, even if it's just to run an errand, but maybe my strength isn't what it used to be, who knows.
I not real sure that I wanted to go the route of a new slave, putting money into something I might not keep. My friend converted to cable and put an EZ clutch in at the same time, it's so easy to pull the clutch now. It's also adjusted to grab sooner, makes taking off pretty easy.
I was just trying to see if anyone else's clutch was hard like mine and hoping maybe it was something simple and easy, like change the fluid, or take it apart and clean it, or maybe it's bent from when I laid it down in Aug.
Old Apr 17, 2023 | 06:48 AM
NorthWestern's Avatar
NorthWestern
It may not be the purpose of your thread, and you clearly don't want to hear it, but the Muller slave solves this issue. Trust us.
Old Apr 17, 2023 | 07:08 AM
HD_noobie's Avatar
HD_noobie
So hard to judge hand strength but it shouldn't be overly hard to do.
When I first got mine it seemed hard to do, then I adjusted the levers upward so I'm pulling it more straight back.
Helped a lot.
Old Apr 17, 2023 | 07:41 AM
Oko's Avatar
Oko
Okay, I'll play.....a can of spinach?
Old Apr 17, 2023 | 08:04 AM
Punjabi Rider's Avatar
Punjabi Rider
2020 clutch pack was improved with different spacer part # 3700295 which made the engaging point little easier also felt like easy to pull. Before it was installed on my 2017 CVO Limited I had adjustable clutch lever but since then it was unnecessary..
