I haven't had a chance to purchase the service manual for my Limited, thus my question is doe the Front Fairing get removed the same as the 2013 & earlier? Are still those 2 pain in the *** screws beneath the fairing by the forks?
Thanks! Going to install a cig lighter, the only issue is that its on the right side of the fairing (i.e. throttle side) which makes it hard to use when riding.
1. Take two old socks and put them over your cruise/spot lights, prevents scratching fairing.
2. Remove the 3 bolts and the windshield, remembering the bolt pattern
3. Remove the 4 inside fairing bolts also remembering the bolt pattern.
4. Pull off fairing enough to remove the headlight molex plug, find good place for fairing.
5. Your golding.
