Okay, I found the right part: 67800241 I think I may go this route so the LEDs match.
The LED strips I used I got at the local auto parts store
The offer them in different lengths and colors.
After some brain storming and studying the wiring diagram I had wired them into the harness going to the rear fender using 1 resistor diode for the marker lights and 1 regular diode (for full power)for the brake light) as the lights I bought only had a power lead and a ground lead. Then I found this little critter browsing the light shop on the HD parts page http://www.harley-davidson.com/store...wiring-harness. Hope this helps
I think the lights look great. However, my question is if we install these and remove the tour-pac so the lights work as run, brake and turn, where do we mount the license plate bracket? Sorry if I side tracked the thread.
I took the license plate bracket that comes with the tour pak disconnect kit and put it in a vise and made it a lay down bracket instead of the straight up and down that looks dumb!
I finally took the time to install these yesterday and these things are bright as heck. Actually surprised at how bright they are, hope it helps with all the idiots out there,
As far as I know they have always been $250. I got mine before Christmas and It was $250. I did get 25% off thru the dealer that made it a bit easier on the budget.
