TBW color code HELP!
Old Dec 20, 2014 | 12:49 PM
Afdharley's Avatar
Afdharley
Default TBW color code HELP!
I'm searching but not having much luck.
Installing a SE TBW and have to swap the male ends for female. Can those be found at an auto parts store?
I also need the color code since this one is different colors than the stock one. You know, which wire matches up with the factory color.
I'll keep searching but thanks for the help.
Old Dec 20, 2014 | 01:12 PM
dawg's Avatar
dawg
Pins and sockets available at dealer.
Old Dec 20, 2014 | 01:19 PM
Afdharley's Avatar
Afdharley
Thanks, actually just found that diagram too.
Can the pin ends be found at an autozone, or do I need to make a trip to the dealer?
Old Dec 20, 2014 | 01:57 PM
dawg's Avatar
dawg
Probably just the dealer
Old Dec 20, 2014 | 02:32 PM
Gwaxley's Avatar
Gwaxley
Good pics here, second page hand drawn connector wiring and explanation. Used this when I changed bars.
https://www.hdforums.com/g/album/1569526
Old Dec 20, 2014 | 04:13 PM
Afdharley's Avatar
Afdharley
No luck at autozone but it was close so I figured worth a shot. Had to go to the dealer.
All set now. Wiring connections all done, I'll button the fairing up tomorrow. Dark and lighting in garage isn't that great and I don't want to scratch anything.
I had to take off the 12" Yaffe monkey bars and put the stock ones back on. Trading it in early next week for my new CVORGU and these were too high for MD inspection laws (which I think are bogus). Dealer made it worth my time on the trade to do the swap back.
On the original install I was able to get the green plug past that first bend but there was no way that thing was coming back out. Had to cut it. Luckily I still had the SE TBW that I didn't use on the install. Just had to swap the ends and we're all good.
Thanks again for the help.
Old Dec 20, 2014 | 04:45 PM
Northbound Southerner's Avatar
What tool did you use for attaching the new pins? Looking for one. Someone ran off with mine and they are spendy...
Old Dec 21, 2014 | 11:54 AM
Afdharley's Avatar
Afdharley
^^^^^ I used a needle nose pliers. Probably not the best method but it worked and the connections are good and tight. If I were to have to do this on a regular basis I would get the correct tool. I just don't see myself doing it very often.
Light was bad last night in garage so I waited until today to button everything up. Took just under an hour and everything works as it should. No trouble codes.
Gonna do the bike swap with the dealer Tuesday afternoon or Wednesday.
Old Dec 22, 2014 | 07:29 AM
crimson13's Avatar
crimson13
This is the one I use, works great.
http://www.ebay.com/itm/CRIMPER-TOOL...6f03ea&vxp=mtr
Brian MD.
Aug 12, 2013 11:13 AM
dk79e
Powdercoat & Paint
Jan 19, 2011 12:00 PM
BlackPearl#1
Jun 14, 2010 01:54 PM
Rocker_Dan
Oct 2, 2009 11:36 PM
