Moisture In Gauges
Old Jan 19, 2015 | 09:13 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
Default Moisture In Gauges
So far on my 14, I have not noticed any moisture in the gauges as has been the case on my 2000 and 2009. I have been out in damp weather the last 3 rides and all is fine.
Has anyone else noticed anything different?
Old Jan 20, 2015 | 03:05 AM
kh24's Avatar
kh24
I've never had a problem with moisture on any of my previous bikes nor the new one. All the gauges, new or old, have a little silica pack in the casing. The old ones were sealed with a rubber pressure fit ring, the new ones are all sealed using very strong double sided tape.
Old Jan 20, 2015 | 05:05 AM
cycle7447's Avatar
cycle7447
Community Influencer
Glad to hear this. I did have moisture in my 2004. Took it to the dealership several times and they finally said there was nothing they could do. Throughout the day, the moisture would go away.
No problems with my 2011 - and none with my 14.
Old Jan 20, 2015 | 10:43 AM
texaspirate's Avatar
texaspirate
I have always had this issue with my 07 gauges. Rubber seals are difficult to keep out moisture and if you live in humid climates it happens often. My 14 never is a issue.
Old Jan 20, 2015 | 07:58 PM
DeeRoe's Avatar
DeeRoe
In the olden days, I would take a small drill bit and CAREFULLY drill as small hole in the back of the plastic housing. This would allow air to circulate better and reduce the possibility of trapped moist air that causes the condensation. FWIW.
Old Jan 20, 2015 | 08:12 PM
TcHunter's Avatar
TcHunter
I hate to be the one to say yes, my buddy has a 14 limited and the dealer had to swap out the gauges because of moisture. And for some reason they threw in the HD cluster rings for free.
Old Jan 21, 2015 | 06:50 AM
oakspeed's Avatar
oakspeed
gauges are fine, but the infotainment screen is full of "fog".
going back to the dealer next week to see what they can do.
Old Jan 21, 2015 | 09:15 AM
RonaldNC's Avatar
RonaldNC
Yep... my gauges had moisture in them... now it's dried, but I can still see the streaks. Will get the dealer to look at in on my next service call.
Old Jan 21, 2015 | 02:33 PM
tommyj's Avatar
tommyj
Default Infotainment Screen Fog
My 2014 screen sometimes is foggy but slowly dissipates after awhile in the sun.
Old Jan 21, 2015 | 07:26 PM
mikeman54's Avatar
mikeman54
I've had 3 Ultra's and all have had moisture in the gauges,seems more in the early morning's and colder weather,always clears up but you can see the streaks.
