Mini Apes
Old Jan 25, 2015 | 08:45 AM
gwellis's Avatar
gwellis
Originally Posted by craigffb
He's referring to the Bat Wing Mini-Apes
P#: 57485-11 Black
P#: 57474-11 Chrome
Can't help you out other then saying I have em on my bike and like them. They put my hands about a fist above the faring.
They look good on your ride! Really like the names you gave your sleds!
Old Jan 25, 2015 | 11:01 AM
offthewall's Avatar
offthewall
Originally Posted by gwellis
What height do you think the mini apes are compared to Yaffe etc> How are they for big mile days?
From those photos in this thread, they look to be about the same height as Yaffee 12" Monkey bars. Definitely higher than my 10" PYO MBB's.
Old Jan 25, 2015 | 11:12 AM
gwellis's Avatar
gwellis
HD website really gives a good picture of them on a bike to see the height.
Old Jan 25, 2015 | 01:23 PM
tpcowfish's Avatar
tpcowfish
Off the Wall, do your bars have any pull back ?, i like the height , and what's the name, don't know the abb.
Old Jan 25, 2015 | 04:38 PM
offthewall's Avatar
offthewall
Lightbulb
The bars are 10" black Paul Yaffe Original - Monkey Bagger Bars (PYO MBB's).
They have pull back. I'm not sure of the exact measurement. You can see the pull back pretty good in these photos.
10" black PYO MMB - side view
10" black PYO MMB - rear view
Old Jan 25, 2015 | 08:17 PM
tpcowfish's Avatar
tpcowfish
Thanks bro, they look good, going to go research now, tnx again
Old Jan 26, 2015 | 02:26 PM
dhermann43's Avatar
dhermann43
I'm looking into some apes too, I have long arms and bad wrists so I want something more straighter with little to no pull back.
Old Jan 28, 2015 | 06:06 PM
NWRider75's Avatar
NWRider75
2nd Gear
2014 Ultra Limited
Ok guys I bought the 10" Wild One mini apes and I am DYI the process. The throttle cable and heated grip cables were long enough and of course the clutch and brake cable was long enough. The wires going on the outside of the stock handlebars to the switches are not long enough to be routed outside or inside the new bars.
I went to HD and they ordered the factory switch extensions which were the heated grip and throttle cable extensions. They ordered another set that looks correct in the photos Part # NHCX-J04 to J15. They look exactly like the original ones. Any Ideas?
Old Jan 28, 2015 | 06:35 PM
offthewall's Avatar
offthewall
Originally Posted by NWRider75
2014 Ultra Limited Ok guys I bought the 10" Wild One mini apes and I am DYI the process. The throttle cable and heated grip cables were long enough and of course the clutch and brake cable was long enough. The wires going on the outside of the stock handlebars to the switches are not long enough to be routed outside or inside the new bars. I went to HD and they ordered the factory switch extensions which were the heated grip and throttle cable extensions. They ordered another set that looks correct in the photos Part # NHCX-J04 to J15. They look exactly like the original ones. Any Ideas?
I don't think so. I just did a set of 10 Yaffee Monkey Bagger Bars and the only thing I needed was these.
Switch Wire Extension Kit-69200034
http://www.kutterharleyonline.com/ha...ge_580440596=7
Old Jan 29, 2015 | 03:28 PM
NWRider75's Avatar
NWRider75
2nd Gear
Thank you offthewall. I am officially an idiot. For some reason I had it stuck in my head the extension would tie into the handle switch. I didn't realize it is extended from the fairing side. Your pictures helped. How well did your heated grip module fit inside your bar. Mine is extremely tight and makes me uncomfortable forcing it in?
