Electrical.. issue? Need help...
I inadvertently touched both pins with one lead from my tester, and shorted it out.
I'm old, I thought, OK, so I popped a fuse.
All the fuses are good, but no power at that plug, the cigar plug, and my passing lamps are out.
Suggestions before I take it in for the embarrassment?
And before I get told to
I did. Still lost.
at any rate good luck hope you get it straightened out before it drives you to pull out your hair
oh ahh never mind
Last night every fuse tested good, today found a bad one, labeled P&A.
Reckon I should have double checked myself before I posted...
Back to normal, all is right with the world.
Thanks for the help!!
