White Spots on Lower
Old Feb 23, 2015 | 01:44 PM
Rhettm's Avatar
Rhettm
Default White Spots on Lower
I have a 2014 Ultra Limited. It is kept in the garage. Has 1900 miles on it. Lately, the black anodized part of the lower case has started developing white spots all over it. They kind of wipe off, but they are still there. It looks almost like corrosion, but I can't tell.
Has anyone else experienced this and is there any way to remove the spots or prevent them from coming back?
Old Feb 23, 2015 | 01:57 PM
batman.'s Avatar
batman.
I found the top of my lower on the right side doing something that sounds the same. Found the brake master cylinder was leaking down onto it. Just a small amount but enough to make me notice it was something wrong with it.
Batman
Old Feb 23, 2015 | 05:31 PM
OldMike's Avatar
OldMike
Use S-100 engine brightener.
Old Feb 23, 2015 | 06:30 PM
Roadie09's Avatar
Roadie09
Are you storing any chemicals in the garage (such as-pool chemicals, water softner pellets, etc.)? I have seen the damage those items can do to the aluminum and chrome under the right humidity and temperature.
Old Feb 24, 2015 | 04:20 AM
Rhettm's Avatar
Rhettm
No chemicals stored with it. It's in there alone, with nothing else really.
I'll try the S-100. Thanks for the tip.
I have noticed that on humid days here in Florida, the heads start to condense. I'm assuming that's due to the temp difference between the coolant and the outside air, but that really doesn't explain what's going on down on the lower.
Old Feb 24, 2015 | 05:35 AM
rwven's Avatar
rwven
I've had minerals in our well water do that.
Old Feb 24, 2015 | 08:13 AM
Custom96's Avatar
Custom96
I'm thinking its salt in the air/humidity/condensation. Ive noticed it on my front cylinder as well as on my Softail. There have been times where I've opened the garage door and due to temperature changes and humidity, the chrome starts dripping with condensation. I have yet to "taste" it though.... if it tastes salty its probably salt.
Rude dog
Apr 25, 2018 10:15 PM
screamn_eagle
May 29, 2015 01:54 PM
cruzmisl
Detailing
Nov 1, 2011 02:13 PM
Mike67
Jan 9, 2011 09:02 AM
