How many of you folks change all 3 fluids at the same time?
2014 SGS - just turned 7500 and for the extra $25 i always feel its worth it to change all three while Im working on the bike. I know some may say overkill but It also allows me to check for deposits and all.
When i bought the bike used with 2700 i dropped all three to make sure i had what i wanted in there. at 5,000 i did the same thing.
For the record i use Mobile 1 V-twin 20 w 50 for the Crankcase and Primary and Mobile 1 70 W140 for the transmission. (don't want to start oil debate)
I changed all 3 on my '14 SGS this past weekend. Just turned over 5,000 miles. I went with Mobil 1 in the crankcase and Red Line in the transmission & primary, all because of the positive feedback from this and other forums. So far, so good.
Every 5000 all 3 and K and N air filter clean/charge.
On a side note, check your air, yesterday, a few hours after completing a ride, cleaned bike and Front was 36 rear 39.9. I had added some (1.5 to 2 lbs) air about a month ago, happy not to have to this time.
I do the same as this. At every 5K I complete the 5K checklist in the service manual. Probably overkill, but it makes me feel good about it.
Knowing that I am using quality fluids, I don't feel the need to swap the engine oil sooner, and I know the trans fluid could go a lot farther, it always looks new, but I've already got my tools out....
