Operating temperature question...
Old May 9, 2015 | 03:49 PM
polbit's Avatar
polbit
Default Operating temperature question...
I know this question gets asked once in a while, but all I could find was about older HDs. Since this is my first proper Harley, I just want to have a piece of mind knowing my bike is not doing something crazy. So...
Today was 87F, 68% humidity, and it stopped raining. I just got an iPhone holder in the mail, so what's the first thing I did? Mounted the phone and put it on view sensor data from my FP3. Cruising at steady 70-75MPH, the engine temp stabilized at around 255F. This is with Twin Slash Cut Ovals, K&N filter in stock housing, and autotuned FP3 map.
From what I've read, that seems ok, I just wanted to make sure. I don't think I've ever seen over 240F on my prior liquid-cooled bikes, but that's not a fair comparison.
Old May 9, 2015 | 04:41 PM
SafetyMan's Avatar
SafetyMan
I think it may be reading something different... Head Temp maybe.
Mine runs that neighborhoed on HT, but ET stays around 200 +/- a few, up to around 220 in traffic, and that has been true all the way up over 100 ambient down here in San Antone.
Old May 9, 2015 | 05:16 PM
Dynamite17's Avatar
Dynamite17
I have a stock 2014 RK with Harley Street Canons. Will the FP3 autotune provide any different performance for me?
Old May 9, 2015 | 06:31 PM
aviscomi's Avatar
aviscomi
The FP3 is reading the Head Temp
Old May 9, 2015 | 10:32 PM
lp's Avatar
lp
You know I saw a screen shot of the FP3 interface the other day. I'm wondering how they are calculating head temp?
There are only a few temp sensors on the Twin Cam. Engine Temp sensor which is actually on the rear of the front head and the air intake temp which is inside the TMAP.
If you have a Twin-Cooled engine there is a coolant temp sensor as well, but there is no dedicated "Head Temp Sensor" anywhere to be found in any system.
Wondering how the FP3 is figuring that...
Old May 9, 2015 | 11:00 PM
fabrik8r's Avatar
fabrik8r
You are correct, I wish there were more people with observation skills who demand real answers. The OEM ET sensor is mounted in the front head, its an internal contact type sensor and directly reads the front cylinder head temp. When the Powervision came along it added a head temp value view, this is not an actual temperature read directly with a dedicated sensor, its an algorithm that uses data from the ET sensor and several other parameters. After several emails and phone calls to Dynojet I never got a straight answer about this value, exactly how it is factored or how its utilized, I believe that its a calculated guess of the rear head temp used by the ECM to adjust spark timing and fuel, its pretty much useless to end user for the purpose of monitoring cylinder head temperature, because its not a "real" measured temp and it is significantly higher than the actual measured temp of the rear head. The ET sensor provides a direct reading of the front cylinder head temp so for all practical purposes it is the front cylinder head temperature, rear head temps are typically 15-30 degrees hotter than the front when the bike is in motion, highest I've ever seen was 35 degrees hotter than the front, measured with a two channel data logger with thermocouples mounted inside both cylinder heads .
Old May 9, 2015 | 11:04 PM
FinalShot's Avatar
FinalShot
It is not a function of the FP3 as PV has the same channle, the calculations are done by the ECM. Here's a reply I got from Jamie regarding it.
Originally Posted by fuelmoto
There are several temp related channels within the Delphi ECM. The most common channel used is Engine Temperature which is based directly off the 0-5V signal from the ET sensor on the front cylinder head, this channel is reported on the databus as ET. Generally speaking when we speak of engine temp we refer to the data from this channel, we usually consider 240-320F about the normal range relative to conditions, engine mods, and other variables. The second channel is Head Temperature which this is a bit more complex, it is a model the ECM calculates based on the ET sensor, the intake air temp (IAT) and other factors. Head Temp is used within the ECM primarily for Spark Temp correction, for most combination it will run between 260-400F. Note: Heat Temp has been recently added to the PV channel list an is reported as HeadT. The last channel is Coolant Temp which is active on twin cooled and V Rod applications. Hope this info helps...
And, here is the entire thread: https://www.hdforums.com/forum/touri...ead-temps.html
Old May 10, 2015 | 03:22 AM
SafetyMan's Avatar
SafetyMan
My head temp reads 122° when the bike hasn't ran in days... the rest of the temps, ET, IAT, AAT and CT usually read the same.
I figured it had to be a calculated number.
Old May 10, 2015 | 03:29 AM
cdonis's Avatar
cdonis
I see 260s easy riding 75 to 80 mph on my powervision when it 85 to 90 outside air. That's with cams and a proper dyno tune.
Old May 10, 2015 | 06:48 AM
lp's Avatar
lp
Ahh... that explains it. Looking back, it was a PV screen shot I was looking it as well. lol
Thanks!
