Softbfake 2014 Limited
Old May 15, 2015 | 09:39 PM
HogPilot54's Avatar
HogPilot54
Not too bad. I'm 6'2" and hate the stock brake lever.
Old May 16, 2015 | 06:01 AM
Fritz58's Avatar
Fritz58
Stage III
Here are pics.
Old May 16, 2015 | 06:31 AM
mackey69's Avatar
mackey69
1st Gear
Did you get plus 1 or 2
Old May 16, 2015 | 07:28 AM
surfnorthwest's Avatar
surfnorthwest
It is one of the first things I did also to my 2014 Limited. Much more comfortable.
Old May 16, 2015 | 11:21 AM
Deer Stalker's Avatar
Deer Stalker
From above here with extended boards
And I cleaned her just after the pics!
Old May 16, 2015 | 01:30 PM
wlibert's Avatar
wlibert
Originally Posted by teedubya
I'm at 6'1" and also put the soft brake lever on. My only wish is that the foot pad was only about 3/4" higher so I could place the toe of my boot under it.
Originally Posted by duckbagger
I just installed the Softbrake +1 brake lever with the HD extended reach footboards. I really like the SB angle and it's a vast improvement, but wish I'd gone with the +2. I measured the +1 lever and it's only about half an inch longer than stock. I'm 6' even, 32" inseam BTW.
I took mine off because I lost the ability to slide my foot under the brake pedal. With the Softbrake I lost a good 2+ inches of foot room.
Old May 16, 2015 | 03:44 PM
Red's Avatar
Red
I hated the OEM pedal for the same reason you like it. Hated to get my toe stuck under the pedal. Unsafe as heck I thought. Had to move my foot backwards and up to apply rear brake. With the softbrake I could just lift my toe and apply brake.
Old May 16, 2015 | 07:09 PM
YPD485's Avatar
YPD485
Same here.
Old May 17, 2015 | 06:18 AM
big papa AZ's Avatar
big papa AZ
I also ride with my foot under the pedal. Seems perfect since with linked brakes, there is no need for a rear brake pedal. Can't remember the last time I used it.
Old May 17, 2015 | 11:01 AM
SecondGear's Avatar
SecondGear
Are you sure you shouldn't be using your rear brake more often? They aren't linked all the time....
