Fog light?
Old Jun 27, 2015 | 12:30 AM
mstrobes's Avatar
mstrobes
Default Fog light?
I just can't figure it out. Where do you get or what wire do you use to connect to the acc. plug to run the fogs on the middle switch. I have P/N 69200722. What wire splices or plugs to it?
Mark
Old Jun 27, 2015 | 02:56 AM
Hammz's Avatar
Hammz
Mark
Don't have my service manual w/me in SD, but it is a switched power lead (low amperage, no relay) that's wired into the accessories plug. The middle switch on the left console is empty but can be populated with the same latching switch used for Ultra or Limited models in the left position of the left console.
Here's the installation instructions from a full switch kit for 2014 & later.
File Type: pdf
Old Jun 27, 2015 | 07:14 AM
mstrobes's Avatar
mstrobes
do I install the fog lights wire to the acc. plug instead of the plugging to the driving lights?
Old Jun 27, 2015 | 01:09 PM
mstrobes's Avatar
mstrobes
ok got it
If you want to run the fogs with the driving lights plugs the wire harness into one of the plugs on the forks. If you want to run the fogs on the 2nd switch you cut the ends off the wire harness, run the wire harness under the tank and black to black on the acc. harness and pin gray to #8 hole ( black is #5 and red/blue is #1).
Mark
Razir66
Sep 3, 2014 03:49 PM
Bigg Lou
May 9, 2014 02:18 PM
CroGlideUltra
Jan 5, 2014 07:23 PM
pontiac69
Aug 3, 2012 05:34 PM
SteveO
Mar 28, 2011 08:32 AM
