What are you running for octane in the twin cooled 103? Recommended 91, but I know in the metric world a lot of people run regular and believe the bikes run better.
If You run regular it will knock and ping.I learned by accident!Grabbed the wrong pump handle and said, oh well,filled up.Pinged and knocked until I filled with premium gas.
I'd stick with 91. The ECU will back out timing if it detects knock so you may not hurt anything with lower octane but you sure as hell won't help anything.
I'll tell anybody all day not to run more octane than they need, but these engines really should be running on premium.
Also the metric bikes don't really compare. When conditions are right you can make more power with less octane, however you need octane to cope with more heat and HD's liquid cooling almost isn't liquid cooling at all. Those metric bikes run a lot cooler.
Octane is additives to reduce pre-ignition of gasoline. It in itself does not increase performance. 91 is the minimum HD recommends for the 103. If you want to give lower octane a try, go for it. But, I'm betting the first hot day, pulling a hill, or accelerating you will wish you hadn't tried to save $2 on a fill up. Be prepared with some good octane boost like Lucas, when you find out why HD recommends 91.
The 103 is a low RPM torque monster. The torque partially comes from compression. Where as stock metrics are rev animals, and many have lower compression and can run on lower octane. Don't even begin to compare the 103 to metrics.
