How check rear tire air pressure?
Old Jul 29, 2015 | 03:57 PM
IUOE ROB's Avatar
IUOE ROB
Looks like no matter what valve you use it's either one of two ways, remove the bag or lay on the ground. I lay on the ground, easy getting down, not so much getting back up...can't understand why some type of pressure monitoring system isn't standard on all bikes, you only have 2 tires. I check mine every time I ride, wanna know if there's gonna be a problem before I have one.
Old Jul 29, 2015 | 04:49 PM
SoFloRod's Avatar
SoFloRod
1st Gear
Originally Posted by indiggio
Wouldn't something that heavy throw off the balance of the wheel/tire?
Believe it or not, they are lighter than the rubber factory valve stems.
From the sellers listing >
Not only they are much safer than the rubber valve stems, they are considerably lighter as well. Each valve weighs in at only 11grams (0.388 ounces)!
Old Jul 29, 2015 | 05:49 PM
RushKing14's Avatar
RushKing14
I just roll the bike until the valve is in the 7-8 O'clock position. Then place a rag on the ground behind the right bag, and kneel on the rag. It is pretty easy to reach in and check it and or air it up with a 90 degree air gauge and air fitting. Takes less time to do than removing the bag.
Old Aug 1, 2015 | 01:21 PM
FLYER's Avatar
FLYER
I put on a set of stem cap tire monitors that you would read out the pressure on a screen. They were inaccurate and useless, so I bought the extension mentioned and just check the tires the old fashioned way. I wish I had put those angled tire stems on at the last tire change.
aqua754
2014-2024 Touring Models
51
Sep 20, 2017 08:33 PM
Whiskers
May 20, 2015 10:40 PM
Boxer 6
Sep 27, 2014 11:31 PM
tidbit1
Apr 6, 2011 08:06 PM
ext1bab
May 20, 2010 11:48 PM
