Accessory switch for Heated Gear?
Old Aug 29, 2015 | 05:16 PM
eric95's Avatar
eric95
Question Accessory switch for Heated Gear?
I have a 2015 Road King with the accessory switch on the right side which connects to the plug under the left side panel. Does anyone know if there is an adapter for the plug to accommodate heated gear? I don’t see anything on Gerbing’s or Harley’s websites. I realize I can wire directly to the battery but I would like to utilize the switch if possible.
Thanks
Old Aug 29, 2015 | 10:35 PM
NODYNA's Avatar
NODYNA
You want part # 69200722 "Electrical connection update kit - touring" firs 14-later touring models, page 731 2015 catalog. It connects to the aux switched power connector under the seat. For my heated gear connection I went directly to the battery and run the cord up the riders seat back support opening. If I'm not on the bile the heated clothing is not plugged in so I'm not worried about running the battery down. My hearted seat IS run of the aux switched power connector because I could leave that on when I'm off the bike.
Old Aug 30, 2015 | 10:22 AM
p51bombay's Avatar
p51bombay
Before you think about running heated gear through that you'd best be checking the amperage rating on that circuit. Heated gear can draw up to around 21 amps and while I may be wrong, I'd guess that the accessory circuit is less than that.
mastery
Feb 3, 2014 04:36 PM
Iron_Yeti
Jan 8, 2012 09:59 PM
MADHOG
Dec 21, 2011 11:56 AM
ford
Mar 15, 2009 08:18 PM
jetfuel320
Dec 22, 2008 06:18 AM
