Extra
Old Sep 21, 2015 | 10:57 AM
p51bombay's Avatar
p51bombay
Originally Posted by MilesOfTexas
Which Hella lights are you using and do you have a pic of how you mounted them? I have been looking at options to do the same thing.
Check out his sig photo
Old Sep 21, 2015 | 11:17 AM
MilesOfTexas's Avatar
MilesOfTexas
Yeah, bit hard to see though. Would like to see how he has them mounted to see if they will work with my lowers.
Old Sep 22, 2015 | 09:48 AM
Yukon42's Avatar
Yukon42
Used Hella 500 series lights as they are pretty light. After trying several mounting brackets found that PIAA (30740) 360 Series Mounting Brackets worked best (from Amazon). Had to modify the mounting tongue as they had 2 mounting holes. I cut the tongue between the holes to shorten it. They are machined aluminum so not so prone to crack and break as cast aluminum. They have worked fine for me for the past 3k miles or so. Here's a pic of how they are mounted:
light mount
I replaced all wiring inside the lights with 12g and used that also for wiring up to battery etc. That way I can use 100w bulbs if I so desire and the wire will handle it.
slowrollin
2014-2024 Touring Models
17
Aug 12, 2017 11:25 PM
dyna bob 583
Electrical/Lighting/Alarm
Jun 15, 2016 12:25 AM
timidones
19
Oct 17, 2015 09:44 PM
SoZoomMe
Oct 2, 2015 09:43 AM
dickey551
Oct 15, 2006 10:16 AM
