'14 FLHTCU Considering Adding Graphic Art
Decal? No.
Unless the WHOLE bike is wrapped, (seen it once), vinyl looks cheap to me.
I always smile and shake my head.
Properly airbrushed and clear coated isn't horrible, but I see a lot of eagles on fairings, looks cheesy, cheap and gaudy to me, to borrow Dave's thoughts.
But these are merely my opinions and to each his own, it's yours, and if you like it, do it.
I've got a CVO and while the paint is a little over the top, I really like it, flames, hard candy paint, plenty of chrome.
The first thing you could consider is putting the Trim covers on the passing lights, it gives it a touch of nostalgia and it really grew on me and i think you would like it.
You have a great color combination on your bike, one that is not very common.
I would give it a little more time and consider some smaller well placed, personalized paint pin stripping, something a little different than you ordinarily see.
I wouldn't do the big decal.
I like the tag for the trunk, but i'd rather it be painted "Comic Sans" type font.
I am including two pics of my bike only to show you the passing light chrome trim and turn signal trim.
Stop by the dealers next event, normally a good turn out of bikes that have been striped etc.
Good luck making your decision.
In the end, its yours, you paid for it, if you like it go for it.
Decal? No.
Plus you could hide the edge on the fairing pinstripe.
Do the "Fly like an Eagle" script in the same Font, size font, and color as the H-D script that would be right below it.
I say go for it.
http://www.markbrodieinc.com
My wife really wanted the graphic (the bike is titled to her because I'm retired .... should have had her co-sign instead, for other reasons) and I wanted the tag.
Cost was very affordable. It would have been about $100 including the install if the Eagle graphic hadn't needed to be processed with the trimming in white instead of a blacked out background in the original.
Giving thoughts to having a couple more decals of this one of a kind graphic made for the Van rear window and the trailer. Even considering having matching t-shirts made now that the original Eagle (on black background) has been "touched up" to go with any other color desired.
They are removable and may cause some paint issue if taken off, mostly shading effects of sunlight and shadow that should be able to be buffed to address this ... IF they are ever taken off.
I like the aggressive looking Eagle and the size of the graphic doesn't seem gaudy to me. I like the meaning of the tag too.
Whenever I "Fly" by someone I'm passing I think the tag on the tour pack leaves a subtle impression.
BTW Thanks again for all the comments.
