RushMore Lean Angle
Old Nov 24, 2015 | 01:42 PM
wndchsr2's Avatar
wndchsr2
Default RushMore Lean Angle
I was going through the specs comparing the 2015 Limited against the 2015 CVO Limited.
I noticed the lean angle is slightly more for the CVO Limited and was wondering why.
The specs for each bike is:
Limited CVO
Seat Height Laden: 27.3 28.4 Only real difference I see
Seat Height, Unladen: 29.1 29.1 Same height there.
Ground Clearance: 5.3 5.3 Same
Right Lean Angle 31.9 34.3
Left Lean Angle 31.8 33.4
So why the difference in lean angles between the CVO and the Limited of the same year? I realize the CVO is slightly higher laden but the same height unladen though. The frames should be the same, so would the suspension be the factor in why the CVO has more of a a lean angle?
Old Nov 24, 2015 | 01:51 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Different exhaust.
Old Nov 24, 2015 | 01:53 PM
wndchsr2's Avatar
wndchsr2
Originally Posted by NDBadlands4-2
Different exhaust.
Really? You think thats the reason?
I have stock slip ons currently
Old Nov 24, 2015 | 02:13 PM
hbsoldier3's Avatar
hbsoldier3
CVO has premium hand adjustable shocks, the Limited has air shocks.
Old Nov 24, 2015 | 02:23 PM
Custardglide's Avatar
Custardglide
My 2015 CVO Limited has Air Shocks, and yes they're crap!!
Old Nov 24, 2015 | 02:24 PM
wndchsr2's Avatar
wndchsr2
That is probably the real difference I would guess................Bout the only thing that makes sense. I was unaware of the type shock the CVO used.
Thanks.
Old Nov 24, 2015 | 02:33 PM
A206Driver's Avatar
A206Driver
I would think that it's the narrow footboards on the CVO.
Old Nov 24, 2015 | 02:57 PM
p51bombay's Avatar
p51bombay
14 and up CVO LTD's come with the same air shocks as an Ultra or LTD.
Old Nov 24, 2015 | 03:33 PM
TomboAT65's Avatar
TomboAT65
It may not seem like a lot but a little over 1" in unladen distance could definitely increase the lean angle before you start scraping stuff.
Old Nov 24, 2015 | 05:39 PM
hbsoldier3's Avatar
hbsoldier3
Quote:
Wow, I got my head up my *** again.
