I just received the Daymaker LED projector headlamp and the 69200897 adapter harness for a 2014 Road King (US model). I haven't started the install, but right off the bat I have a question. The adapter harness directions start off with 1) cut the OEM harness connectors off.... Then later a bunch of splicing....
Is this right? I thought the whole point of tha adapter was to directly connect to the OEM harness.
Thanks,
Bob
Bob, you're absolutely right. The Road King is the only one you have to cut and splice. I refused to do it. I used a Trucklite. This would work for you if you could get one other adapter.
