Got new windshield bag, it has foam strips,new washers between inter and outer fairing. So is it needed to put them on, is there going to be a gap with the extra addition. Thanks in advance
I used both the strips and washers.
Washers as the bag adds thickness, strips to help seal the top part of fairing.
Sorta helps avoid paint cracking around the screws....but I added trim
A bit of adhesive on the washers is a thought....little rascals were hard to keep in while inserting the screws
