Nav screen display options
Old Mar 13, 2016 | 08:54 PM
JDHunz's Avatar
JDHunz
Default Nav screen display options
Picked up my new Ultra with the 6.5 Boom...I've read and reread the manual and can't find an answer...
At the bottom, is it possible to display the time/clock and not the audio source? Maybe I've overlooked it, but haven't figured it out as of yet.
Thanks!
Old Mar 13, 2016 | 09:19 PM
jamiesmithnc's Avatar
jamiesmithnc
There are different areas at the bottom that you can click, and set what shows there, but I think that they depend on whether or not you are being directed to a location. You should be able to put the clock in one of the slots
Old Mar 13, 2016 | 09:23 PM
Prairie Shark's Avatar
Prairie Shark
There is a left and right "data field". You can choose what to display. Page 148.
Old Mar 13, 2016 | 09:44 PM
ROCKOUT Rocker Products
Sponsor
You can also press the "info" button on the right switch housing for a quick check of the time.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 14, 2016 | 12:39 PM
wparente's Avatar
wparente
I just have 150 miles on so my memory may be faulty, but I believe you can set it up to have the clock on the left up with the map. However I believe if you have route guidance on to a destination the clock disappears and the radio station goes in its place. If you are using usb media I'm not sure what happens. Seems confusing and questionable to me but....
Old Mar 14, 2016 | 01:08 PM
GTK's Avatar
GTK
Thumbs up Winner
I choose this as the best answer out of the bunch.
Old Mar 14, 2016 | 07:09 PM
Punjabi Rider's Avatar
Punjabi Rider
Just play with it with NAV map screen on touch any icon with your fingertip and you will notice all the options and if you see an arrow up/down on the right side of the screen that means you have few more option to scroll down. It doesn't explain avery thing just like the smart phones more you use/play with more and more things you will find out. Plug in your battery tender turn the ignition to acc enjoy some adult bev and spend some time with it in the garage it's lot to learn.
Old Mar 14, 2016 | 07:11 PM
Punjabi Rider
Also congrats on your new ride .
Old Mar 14, 2016 | 08:16 PM
JDHunz's Avatar
JDHunz
After playing with it a bit and going back through the manual, all is good!!! Thanks all!
Old Mar 14, 2016 | 08:27 PM
Ridem-Rhody's Avatar
Ridem-Rhody
http://boombox.harley-davidson.com
