Doesn't make sense
Old Mar 25, 2016 | 12:03 AM
SpiderPig's Avatar
SpiderPig
Originally Posted by '14 Limited
Yep...take the Syn 3 out of the primary and put in Formula+. It shut mine up immediately.
I will dump the Syn 3 and run some Formula + on Saturday. Hard to believe an oil type would be causing this but I will give it a go. Thanks for the suggestions guys!
Old Mar 25, 2016 | 06:01 PM
SpiderPig's Avatar
SpiderPig
I go and pickup the bike today and yet another "Doesn't make sense" moment. Check the notes from the tech and I see that they did in fact update the ECM with a new map. however they marked the records that they checked the trans fluid and have a notation "NON HARLEY TRANS FLUID" now I can understand if I had the Red Line shockproof that looks like pepto pink. But it has Syn 3 from the 1000 service that they did, WTF. I will be in there tomorrow morning to ask just HTF they can determine that the trans fluid is "NON HARLEY"? Now I am worried that if there is a failure they will deny warranty due to this "NON HARLEY" fluid notation!
Old Mar 25, 2016 | 07:46 PM
OldMike's Avatar
OldMike
WTF!
I don't even want to know you.
Old Mar 25, 2016 | 08:14 PM
lp's Avatar
lp
Get your answer, and get the hell out of that place and never go back ever.
Old Mar 25, 2016 | 10:32 PM
Greatsteaks's Avatar
Greatsteaks
Primary chain is about to self adjust. Make some sudden rear brake stops and it should adjust to the next click. Mine was real bad then adjusted itself and has been fine ever since. Harley also has a bulletin on a noise in neutral (pull in the clutch or rev it and it goes away)in the trans that says the noise is normal.
Old Mar 26, 2016 | 05:29 AM
ILLADELPHFATBOY's Avatar
ILLADELPHFATBOY
Interesting, being as the tensioner is "self adjusting" and unlike the older bikes, cant be adjusted per se. Heck, try different fluid first, as thats the cheap fix. I know plenty of people have opted to replace the stock tensioner with an after market unit that is metal and is adjustable. I believe Baker makes one.
Old Mar 26, 2016 | 01:13 PM
cycle7447's Avatar
cycle7447
Community Influencer
Got my bike home today - put SYN 3 is 2 holes and formula in the primary - seems to sound a lot better. Bike was idling at both the dealership and at home in the garage - did not sound like it wanted to cut off.
Will hopefully have some nice days coming up and an opportunity to ride and better determine if this makes a difference.
snoski1
Milwaukee Eight (M8)
Jun 28, 2018 10:37 AM
jumpinjoe313
May 23, 2016 07:56 AM
Axegrinder
2014-2024 Touring Models
46
Jan 3, 2015 08:55 AM
DaddyKnuck
Nov 6, 2014 10:49 AM
BKSinAZ
Sep 2, 2012 02:26 PM
