Interesting idea and some ?s ...
Pretty damn cool this guy put one in a GMC dually, truck is a little ratty, but I would drive it!
Typical diesels do not have a throttle blade..Air amount in is constant ( a few models do actually run a throttle blade but not many)
The throttle cable effects the amount of fuel supplied not air and fuel
Gas motor do.
When the air keeps getting sucked into the diesel engine it creates a run-on condition.. Air fuel heat compression =combustion
Gas motors have a throttle blade. Once throttle is let off blade closes.. Less air comes into motor.. Same effect as releasing the excess air with a valve.
Posting this quickly so if I missed or skipped something I apologize...
Now If you went with a flapper style exhaust brake......
Gas motor do.
For those that are thinking ... "Why would anyone ever want to do this for?" ... Well, if you drove truck like some of us you would have your answer. I always use my engine and trans to do most of my slowing, same way I drive a truck. It would be cool to have a little more extra engine braking than I already have without using the brakes. I sort of already have the sound of a jake with my ProPipe, but I would love to have the real deal if possible. Just think ... riding along, slowing down, roll the throttle off and ... BWAAAAAAAAAAAAAAAAaaaaaaaaaa .... I would be in my glory, lol. What do you guys think about this?
#2, The reason why we currently have engine braking is from a high vacuum condition in the engine from the throttle valve being closed, the pistons are trying to suck in air that isn't there (which Tedwilliams09 reminded me of, that I forgot about) which gives any engine a retarding effect.
#3, This is why the way the ACRs operate is so important ... if they stay open continuously, then you would lose that high vacuum as the pistons comes down on intake because air would be drawn from the ACRs still being open so you would lose THAT retarding effect. BUT, if they actually cycle with engine revolution (like a real Jacobs Engine Brake does) and only opens right before TDC, it would have BOTH retarding effects from high vacuum AND also the loss of pressure downward on the pistons since the compression stroke is exhausted instead ... best of both worlds. The problem there that Ted explained is the volume of air is less with the throttle valve being closed. Like he said, most of your bigger diesels do not have a throttle valve so you get a constant volume of air at all times. Also the same reason a big diesel slowing down without a jake is almost like free-wheeling in neutral, you have no engine vacuum, our bikes have more engine braking than a big diesel does ... unless you turn the jake on, THEN you have engine braking.
#4, Do the ACRs have enough power to push the valves open right before TDC like a jake without the aid of hydraulic press like a jake? If not, what if you opened them just past BDC instead? That way you're still releasing compression without the sudden force of trying to open them right before TDC ... would be more of a gradual loss instead of a quick loss, not sure if the effect would be the same or not as in retarding ability.
Do I NEED to do this? ... no. Do I WANT to? .. yes! ... It's one of those "beat your meat" things you can do without, but would be cool to have. I was hoping someone knowledgeable with the actual workings of the ACRs would chime in here, but no such luck or they just don't GAS about this brainfart of mine, lol. From the sounds of all this, it would probably be easier to plumb a butterfly in the pipe for an exhaust brake instead of trying to turn the ACRs into a real jake, but I want the real deal or nothing. I know there are people smart enough in this forum to help me figure this out, but is it really worth it? ... probably not and will most likely die as another "pipe dream".
The HD ACR doesn't do anything to your valves. It opens to release compression into atmosphere. It's drilled into the combustion chamber like manual ones but is hidden because you don't have to touch it.
Again, the stock HD crankshaft is really not the best thing to be pressing back on. It's a "good enough" part on the motorcycle, and would probably have a premature and catastrophic failure.
Yep best left as a pipe dream.
