catalytic converters???
Old Apr 24, 2016 | 11:29 PM
whocares's Avatar
whocares
Originally Posted by zoozoo
My 2010 FLHTC had the cat in the pipe. The 2009 models were in the muffler.
When I bought my 2009 roadglide new ,there was no cat.I belive cats started in 2010.
Old Apr 25, 2016 | 06:45 AM
pkwett94's Avatar
pkwett94
On my 2014 it was in the head pipe as shown. I too did the window trick and it works well.
Old Apr 25, 2016 | 07:24 AM
Just Me's Avatar
Just Me
My bad, you are correct.
Old Apr 25, 2016 | 09:57 AM
caddman's Avatar
caddman
Originally Posted by Just Me
Been in the pipe since 2011
2009 actually.
Old Apr 25, 2016 | 09:58 AM
caddman's Avatar
caddman
No, I have a 2009. the Cat was in the head pipe.
Old Apr 25, 2016 | 10:20 AM
swing2hard's Avatar
swing2hard
This is probably a dumb question but if you take the Cat out will it throw a code on the bike?
Old Apr 25, 2016 | 10:42 AM
Davidson Harley's Avatar
Davidson Harley
It probably will not throw a code. BUT! You greatly reduce the back pressure so the bike should be re-tuned to match this set up. Or you run the risk of improper fuel mixture and some damaged heads.
Old Apr 25, 2016 | 11:36 AM
batman.'s Avatar
batman.
When i cut mine I cut it half way around with a grinding cut off wheel and then turned it over and stepped it over width of the wheel and cut the other half so it made a "Z" on the pipe. When I welded it back up held it at the "Z" part together and welded it back up. No alignment issues at all with it having a clocked position to reset to. Now if It was cut completely in half one shot thru then yes I could see a alignment issue.
Batman
Old Apr 25, 2016 | 11:54 AM
todd-67's Avatar
todd-67
It was not in my 09. Still have the factory exhaust in the basement.
Old Apr 25, 2016 | 12:26 PM
Greatsteaks's Avatar
Greatsteaks
Shouldn't be. Do you have a California bike? Not even sure if that matters.
