Sync Addresses
Old May 20, 2016 | 08:16 AM
cycle7447's Avatar
cycle7447
Community Influencer
Default Sync Addresses
My android phone is paired with my Boom Box.
When I go to the phone on the Boom, I can see all of my contacts - as well as the phone numbers. However, when I look at the addresses - none are listed.
Those addresses are indeed in my phone and on my contact list.
Am I missing something?
hanks
Old May 20, 2016 | 03:14 PM
MilesOfTexas's Avatar
MilesOfTexas
hanks
That is because you are looking from a phone call perspective. Go to the NAV system and you will be able to see the same contacts and you will get the option to navigate to the address.
Old May 20, 2016 | 07:05 PM
cycle7447's Avatar
cycle7447
Thanks - your comments made sense so I went to the garage. Opened the NAV system.
Hit where to - saw the phone book and opened it. I had the option of opening the saved on bike or saved on connected phone.
When I went to saved on bike - there was nothing there. When I went to saved on connected phone, I could see all the contacts and numbers - but the address was still blank.
Earlier, I unpaired the phone and re-paired it hoping or thinking that was the matter - but found no difference. I did check the boom instructions - but was not able to find this.
If someone can share a bit more, I would appreciate such.
My bet is - a later phone app will come out that will let you send directions right from your phone to the Boom - like my car and truck does.
Thanks again for any and all help
Old May 20, 2016 | 09:00 PM
Kugie's HOG's Avatar
Kugie's HOG
Check and be sure on Nav Sytem that United Stateszand not Canada is the country showing
Old May 21, 2016 | 01:16 AM
cycle7447's Avatar
cycle7447
Where am I checking for US vs Canada? I can input my addressees manually - so, it appears the system is signed into the US?
Old May 21, 2016 | 06:36 PM
cycle7447's Avatar
cycle7447
I have done a little more research- looked in the 2015 Informat online and found some additional info. They talk about loading saved phone book.
I tried all that said but nothing works. Going further, it might be that my phone has Gmail contacts and not Verizon contacts. Think that might be a difference. ill see if I can convert.
Old May 21, 2016 | 09:15 PM
cycle7447's Avatar
cycle7447
I can now see the same files in google that I see in Verizon - was able to sync.
I again unpaired my phone - and repaired it - saving all contacts. All phone numbers are there - however, when it comes to an address- it does not show an address.
Several folks have said it works - hopefully someone will come on and share how they did it.
Thanks
Old May 21, 2016 | 09:59 PM
Hammz's Avatar
Hammz
Don - sadly, the contact address info appears to not be shared on Apple devices? I did a bit of research & found that Apple doesn't even allow contact address info to be saved/shared via iCloud.
iPhone owners - if this info is incorrect, please chime in.
Old May 22, 2016 | 06:29 AM
cycle7447's Avatar
cycle7447
Thanks - and I wondered if it was a phone matter. I have an Android
I will continue to look and see if I can export/import a few addresses and put them in the saved file. If not, i may just type them in.
Have a few trips coming up soon and want to give it a try. Thanks again - see you in a few weeks if not at the dealership sooner.
Old May 22, 2016 | 06:35 AM
Hammz's Avatar
Hammz
OK. For some reason, I thought you had an iPhone. Can't check mine cuz I don't have the FLHTK this trip; riding the FXSTB this time just cuz it needs some miles.
