Coolant replacement
Old Jun 16, 2016 | 09:43 PM
lnelson's Avatar
lnelson
Default Coolant replacement
Has anyone flushed and replaced their coolant themselves? What is the process? I have searched and can find nothing.
Old Jun 16, 2016 | 11:22 PM
cfreeze's Avatar
cfreeze
Drain System
1. Remove main fuse.
2. Remove access panel from right lower fairing.
NOTE
Leave pressure cap installed at this time.
3. See Figure 1-6. Remove rubber plug (3).
4. Remove pump/thermostat cover.
NOTE
Hose barb on the pump is fragile. Use caution when removing
coolant hose.
5. See Figure 1-8. Disconnect hose (5) from pump.
6. Drain and discard used coolant.
Using a squeeze bottle similar to a dishwashing liquid bottle
simplifies the procedure. Capacity is approximately 1.1 qt (1.0
L).
4. Fill system through filler neck until coolant is visible. Allow
coolant to bleed down for a few seconds and repeat.
5. Install main fuse.
6. Bleed cooling system.
a. Turn ignition switch ON. Turn run switch ON. Do not
start engine.
b. Turn throttle to greater than 50% and hold for at least
three seconds. Coolant pump and fans will start.
Release throttle.
c. As the pump runs, continue to add coolant until filler
neck remains topped off.
NOTE
Unlike operational mode, the pump and fans will run
indefinitely in bleed mode until ignition is turned OFF.
d. Turn ignition switch OFF. Pump and fans will stop.
NOTE
See Figure 1-9. Verify pressure cap is completely tightened.
Tab (2) must contact stop (1) for proper system operation.
7. Install pressure cap. Secure filler neck to retainer on
coolant bottle.
8. Fill coolant bottle to the cold fill line. Install rubber plug.
9. Start engine and check for leaks when hot.
NOTE
Coolant level in the coolant bottle typically rises when the
engine is at operating temperature. The level will return to the
"COLD" line when the system has cooled down.
10. Verify level in coolant bottle after system has cooled.
11. Install access panel.
Old Jun 17, 2016 | 11:00 AM
lnelson's Avatar
lnelson
Thank you
Old Jun 28, 2016 | 12:20 AM
lnelson's Avatar
lnelson
Got the coolant replaced, very easy...it still looked like new.
Old Jul 17, 2017 | 05:53 PM
EasternSP's Avatar
EasternSP
The manual says 1.1Qts of fluid. Does this include what ya put in the reservoir?
2016 Road Glide Ultra. First coolant change.
I'm running the pump and fans but that doesn't help it. I can feel the pump vibrating.
I was able to pour a little over a pint into the filler and it wouldn't bleed down anymore. I poured some into the reservoir, up to the cold line but I still have almost half a pint left.
I'm going to close it all up and run the bike up a little to warm it up, then let it cool off and check it again and add if I can.
Old Jul 17, 2017 | 06:43 PM
EasternSP's Avatar
EasternSP
OK, I'm inclined to think I didn't drain all the coolant out when I followed the shop manual instructions. Pulling the hose off the pump won't drain it all.
Old Jul 17, 2017 | 06:51 PM
EasternSP's Avatar
EasternSP
I went back out and measured what I drained from the bike. 26oz. I measured what I've put in, 26oz.
Old Jul 17, 2017 | 07:06 PM
josame's Avatar
josame
Does the pressure cap screw all the way off or is it more like a half turn and it will pop off like a car?
Old Jul 17, 2017 | 07:15 PM
EasternSP's Avatar
EasternSP
It comes about 1/3 turn CCW then ya have to press it in to turn it the rest of the way to get it off.
Old Jul 17, 2017 | 07:16 PM
hardheaded's Avatar
hardheaded
it comes all the way off. push down (hard) and turn. it's a bitch, i wish HD would have used a screw on cap.
