Shifting help
Old Jun 29, 2016 | 02:14 AM
  #31
Ron750's Avatar
Ron750
Originally Posted by crabio
I'm a little surprised that no one so far has mentioned something that I learned a long time ago called .... pre-loading the shifter.
I don't remember who taught me this .... but for me now it's a habit I don't even think about anymore.
The concept is pretty simple. When you know you're getting ready to shift into a higher gear, with your toe under the shifter, you put just a small amount of up pressure on the shifter. When you pull in the clutch, your foot has ... pre-loaded the shifter ... and you shift smoothly into the next gear. There's no lag ... no accidently going into N from 1st ...
When I say a small amount of up pressure I mean small. It doesn't take much. Somehow it's keying the brain and muscles relating to the upshift to all work together simultaneously.
Like I said ... I've been doing this for 20 years and I don't even think about it anymore.
Give it a try. It's a pretty neat trick.
I do that instinctively. But I don't think the OP is ready for that. He needs to walk, before he can run.
Old Jun 29, 2016 | 08:04 AM
  #32
rctreadaway's Avatar
rctreadaway
I was occasionally hitting neutral on the 1-2 shift although I've been riding for 10 years now. However I ditched my heel shifter and added an eliminator that replaced the rubber grommet and rear lever. I may have lowered the toe shifter a notch or two as I don't wear big heavy boots but ever since I've had no trouble accidentally hitting neutral. The rubber grommet can possibly cause a little drag but I have a feeling that the biggest difference is that I probably lowered the toe shifter a bit.
Old Jun 29, 2016 | 10:45 PM
  #33
Ryan David's Avatar
Ryan David
This worked awesome for me, thank you! I went for a short ride today and had 0 missed shifts. Preloading really helped.
moto689
Aug 13, 2014 05:47 PM
god61021
Jul 26, 2012 10:51 AM
Magnum 61
Jun 11, 2010 06:29 AM
Vinnie85FXWG
EVO
Sep 1, 2009 09:19 PM
VENNUM
Sep 4, 2008 07:07 PM
