Jump Start
Old Jul 12, 2016 | 10:27 PM
Londonbike's Avatar
Londonbike
Default Jump Start
What's the easiest way to jumpstart an Ultra Limited.? I'm thinking of buying one of those jumpstart battery paks. Getting to the battery terminals not that easy especially on the road. Can you use the tender cable or 12 volt plug on inner fairing or in tourpak?
Old Jul 12, 2016 | 10:46 PM
Casper's Avatar
Casper
First question? Why are needing to jump start your motorcycle? A battery tender will make your battery last over 4 years. If it's older than that, have it check. If you going on a trip and its old, replace it.
Now, if you're on the road and something happens, like leaving the ignition on, the best way to jump any motorcycle is:
Hook cables to motorcycle, have the jumping vehicle turned off! The charging system on cars, trucks is too high an output for the motorcycle electrical system, when jumping vehicle is off hook the cables to the jumping vehicle. Allow the jumping vehicles battery to charge up the motorcycle battery for a few minutes, do not start the jumping vehicle while hooked to motorcycle, unhook all cables and then attempt to start the motorcycle. If it won't start, call a shop and get a new battery after having the electrical system checked.
Another way is to remove the motorcycle battery from the bike, charge with a battery charger or from a running vehicle. No damage to bikes electrical system because battery is removed.
Old Jul 12, 2016 | 10:56 PM
ROCKOUT Rocker Products
Sponsor
If you get the Antigravity brand jump starter they sell a heavy duty harness that hooks to your bike like a tender harness, then the jumper just plugs in.
It's a nice clean setup.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 13, 2016 | 05:59 AM
cycle7447's Avatar
cycle7447
Community Influencer
Having the antigraity jump starter is a valuable tool - I have one in my truck and take it when I go boating. More often than not, a boater needs a jump. I will probably take it with me on long bike trips - heading to MT from MI this summer.
The connector does add some benefits. I do wish someone made a reverse plug - so I could connect the antigravity charger to the current bike tender leads.
Old Jul 13, 2016 | 06:30 AM
Sponsor
I think the current from jump starting would fry the thin battery tender leads.
Old Jul 13, 2016 | 08:27 AM
Vernal's Avatar
Vernal
The Battery Tender leads are too small.
Connect the positive from the Jump Starter to the positive lug on the starter and the Negative to the frame. Much easier than getting to the battery and no extra wires
Old Jul 13, 2016 | 08:35 AM
jlitteau's Avatar
jlitteau
I just had to jump start my '16 RK this week. I tried jumping it with the good car off but it would not turn over. As soon as I made sure my ground was good, I turned the good car's engine on, bike fired right up. No damage at all. Idk if this is the "correct way" but it worked for me.
Old Jul 13, 2016 | 08:40 AM
rwven's Avatar
rwven
The fuse in the battery tender harness will blow if you attempt to jump start the bike through it.
Old Jul 13, 2016 | 11:17 AM
Brewmany's Avatar
Brewmany
Typically you'd not start the jump vehicle- if for some reason there was a voltage spike you could damage your bike's electronics. That wouldn't happen with just the battery, but when the jump vehicle is running the alternator of the jump vehicle comes into play.
Old Jul 13, 2016 | 12:03 PM
cycle7447's Avatar
cycle7447
Thanks for the input on the tender wires. As the OP mentioned, the jumpstart battery pack might be a good option - however, I would need to buy the connector.
My main reason for all of this is, not for the motorcycle but for my backup generator. The house has a backup and the generator is about 5 years old. I am on my third battery. The battery is small and if you don't check the generator and/or charge the battery periodically, it will not start.
One day we lost power it would not crank. It does have a pull start - but trust me, I still could not start it. I have since installed a battery tender to keep it full. However, thought, if I could connect my jumpstart to the battery, all would be OK. Problem is - getting to the batter on the Generac generator is worst than on the bike. So, I would need those cables - cost is $27.00
My jumpstart only cost me a net of $9.99. Here is a tip - got to Amazon order one - apply for their card and get a $70 instant credit. So, the final cost was just the $9.99
