Hi all,
I am confused as to where the connector port is located that the switch kit Part Number 71400106 plugs into?
I have installed both switches and found an accessory port connector behind the Left side cover. I can hear the number 3 switch actuate the included relay on the wire harness with the kit. But the number 2 switch does not do anything. With a 12V test light connected to the supplied wire harness, it is hot when the ignition switch is Off and turns off when the ignition is turned to On or ACC.
Is there a different accessory port connector somewhere else I should be using instead?
Again this is a 2015 Ultra Limited.
I just installed the same kit on a 16 rgs and all the switches work as should it was just plug and play.
If it operates opposite than it should bring back because there is aflaw in harness. There is nothing you could of done to switch function as its all plug and play. All switches should be dead until acc. is on then they become live.
I just installed the jnr air ride switches on my 2020 Road glide limited and now the led lights on my tour pack stay on. I hooked yellow to yellow and white to white , the red was hooked to the green and light stays on . I'm thinking maybe I should hook the red wire some where else and the green is for another accessory, but my instructions were missing . Any thoughts ?
