Installing vindikta bars?
Old Dec 31, 2016 | 02:08 PM
bobbyjoes's Avatar
bobbyjoes
Default Installing vindikta bars?
Hi,I am working on installing the wiring in my vindikta bars,,clutch side was easy,got the right throttle by wire in ,but having hired time with the control wires,any advice ,thanks
Old Dec 31, 2016 | 02:56 PM
Covert Olds's Avatar
Covert Olds
Assuming you have the connectors dissasembled, tape the ends up as small as possible. Electrical conduit lube works wonders too. Super slippery and leaves no residue when dry.
Old Dec 31, 2016 | 03:12 PM
bobbyjoes's Avatar
bobbyjoes
I disconnected tbw connection but not the control wires connectors,not sure how you do those,thanks
Old Dec 31, 2016 | 04:05 PM
Covert Olds
They're not the easiest to take apart but here's a how-to video.
Old Dec 31, 2016 | 04:31 PM
bobbyjoes's Avatar
bobbyjoes
Ok ,will give it a shot,thanks so much
Old Dec 31, 2016 | 05:34 PM
bobbyjoes's Avatar
bobbyjoes
so there is two connectors at the end of throttle by wire the big one plugs in the other dont go anywhere is that for heated grips ,thanks
Old Dec 31, 2016 | 05:38 PM
Covert Olds
Correct. It's for heated grips.
Old Dec 31, 2016 | 05:40 PM
bobbyjoes's Avatar
bobbyjoes
Be easier to cut that off,thanks
Old Dec 31, 2016 | 05:51 PM
Covert Olds
Exactly what my buddy did on his the other day.
Old Dec 31, 2016 | 05:55 PM
bobbyjoes's Avatar
bobbyjoes
Thanks for your help ,appreciate it
