Primary Chain Too Tight?
Old Oct 12, 2017 | 07:16 PM
GalvTexGuy's Avatar
GalvTexGuy
Default Primary Chain Too Tight?
Can you tell from this video if it looks like my primary chain is too tight? It sure feels tight!
Old Oct 12, 2017 | 07:35 PM
Cobra1's Avatar
Cobra1
Looks good to me. Exactly how I check mine and it has about the same play.
Old Oct 12, 2017 | 08:06 PM
Hoginedgewood's Avatar
Hoginedgewood
I’ve been hearing the automatic adjuster gets too tight and ruins the bearing in the transmission, I’ve heard HD makes a Screaming Eagle manual adjuster, but I know years ago after market had a hydraulic adjuster that didn’t get out of control.
Old Oct 12, 2017 | 08:29 PM
GalvTexGuy's Avatar
GalvTexGuy
Yeah, I've read about the dreaded HD automatic chain tensioner becoming too tight and I've always heard "a loose chain is a happy chain." Also, I believe a cold chain should have 5/8" to 7/8" free play. Mine wasn't exactly cold, but it wasn't hot, either. I don't know whether or not I should remove the primary cover and double-check the chain tension and get an exact measurement. I'm thinking I will.
Old Oct 13, 2017 | 07:18 AM
jpooch00's Avatar
jpooch00
I put a Baker Attitude Adjuster manual primary chain adjuster in my '15 Limited the day I bought the bike. When I took the cover off with the bike dead-cold the chain was guitar-string tight (too damn tight!) pretty much just as I expected it to be.
The Baker unit eliminates this potential problem permanently. The auto adjuster adjusts at the "loosest" part of the chain and when the "tighter spot" comes around, there's no way for the OEM adjuster to compensate for it. It's been a total POS design ever since it was introduced on the Dynas in 2006.
I considered the SE manual adjuster but it has terrible reviews, so I went with the American-made Baker adjuster and couldn't be more pleased with its performance.
I do take the primary cover off once a year to check the adjustment, but it's always been fine so far. I'll probably go to every other year in the future.
Old Oct 13, 2017 | 06:08 PM
Darrell07FLHR's Avatar
Darrell07FLHR
hi jpooch00 : I have 2014 FLHX , and after seeing your post I went to the Baker website , with that pop up window they use its very hard to figure out if the tensioner will fit 2014 touring ? would you happen to have a part number for yours ? amazon has the tensioner for around 100.00 less than Baker ? but I can not narrow down the part number . Thanks .
Old Oct 13, 2017 | 08:29 PM
u wish u could ride's Avatar
u wish u could ride
that chain looks perfect! if looser you would be complaining about hearing it knock around.
Old Oct 14, 2017 | 07:08 AM
jpooch00's Avatar
jpooch00
This is the one I got and it should fit yours, too.
Amazon Amazon
I would also purchase the bar-type primary locking tool suggested at the bottom of the page. You'll also need a new compensator bolt (cheap from any H-D dealer or online. Just make SURE it's genuine H-D), the #70 torx bit to remove/install it - be sure to get a top-quality bit for this, an accurate torque wrench with a suitable range, some blue and red Loctite and a new gasket and lube. Personally, I use plain ol' Formula+ with excellent results.
Also, there are great "How To" vids on YouTube if you need 'em.
If you have the tools and follow the Baker instructions and factory manual exactly, it's easy-peasy. Just be certain that you find the TIGHTEST spot in the chain and adjust to 5/8" slack (cold). I found that my chain on my brand new Limited varied by a full 1/4" of slack when I was finding the tightest spot.
Good luck and best wishes,
JP
Old Oct 20, 2017 | 08:41 AM
Darrell07FLHR
Thank you jpooch00.
Old Oct 20, 2017 | 04:19 PM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
I believe the one on Amazon is the older model. The new one is "ARMORED Attitude Adjuster". Call Baker and ask for Mark, he's always on the forum and I believe he offers a discount to members. I have the new one and it's a beautiful piece of work...almost a shame to hide it.
https://bakerdrivetrain.com/collecti...nt=39606989774
