clutch and brake fluid flushes: worth it?
Old Apr 13, 2018 | 02:27 PM
  #91
MilesOfTexas's Avatar
MilesOfTexas
Originally Posted by Two Lane Tramp
Yes you need to flush it. Dot 4 gets moisture in it and can fail. Had it happen to clutch going over Sonora Pass on a hot summer day. Lots of twisties at 9000 feet. Think about no clutch on a 1000 pound bike with back rider. I had to pull over and let the bike cool off for an hour then clutch worked again. Flushed both when I got home.
Yep, same issue on Million Dollar Highway. Flushed mine with Castrol SRF Racing brake fluid. Wet boiling point is 200F degrees higher than typical DOT 4.
Old Apr 13, 2018 | 04:14 PM
  #92
barneyboy's Avatar
barneyboy
Originally Posted by lh4x4
Even the brake fluid manufacturers recommend replacing at two year intervals. It is not dependant on miles just time.
I do mine at the two year interval and it costs less than $1 in fluid ($7 qt at Walmart DOT4).
It only takes 30 minutes, a 3/8th wrench, a drain tube and a phillips screwdriver.
Does not take a vacuum bleeder either. Just pump out the old fluid by operating the brake lever/pedal.
And yes that works just the same for ABS but uses more fluid to flush fully. Just pay attention and don't introduce air into the system as that will require the dealer to use a digital tech to get the air out.
Are these the same folks that change oil every 2,500 miles and use only a certain brand for "peace of mind."
Not changing the fluid is like playing Russian Roulette or riding on tires with the belts showing.
On a skill level of 1 to 10 it hardly qualifies as a 1.
The cost at a dealer is many times as outrageous as the oil change price.
I thought it was recommended to use fluid from a fresh, unopened container. Unless you're doing several bikes with that $7 quart, the unused portion can absorb moisture sitting on the shelf.
Correct me if I'm mistaken.
Old Apr 13, 2018 | 04:42 PM
  #93
Mr-Mike's Avatar
Mr-Mike
FACT! 14 year old fluid
Old Apr 13, 2018 | 04:49 PM
  #94
lp's Avatar
lp
I'm in my garage looking out at my old *** 2003 Murano with 237K on it. It just hit me that I have never changed the brake fluid in it.
I guess I better get on that.
Old Apr 13, 2018 | 06:03 PM
  #95
Cygnusx51's Avatar
Cygnusx51
Too late!!
Old Apr 14, 2018 | 07:54 AM
  #96
alarmdoug's Avatar
alarmdoug
Originally Posted by Grouser62
Hi 2015 Limited, 124,000 km (77,000 miles), brakes and clutch perform as new.........is it really worth it to get the DOT 4 flushed? Fluid color looks fine through the windows. I'm a bit of a "ain't broke don't fix" kind of guy. If I do go ahead, what should I expect in terms of labor hours?
Do you change your motor oil as required in the owners manual?
If so ...
Then you should be changing your brake fluid as required in the owners manual every two years.
Takes less then an hour and easy to do yourself ... or have the dealer do it for a $100 or so.
If you do it yourself, this actually makes it fun to do.
https://www.harborfreight.com/brake-...kit-63391.html
Old Apr 14, 2018 | 08:07 AM
  #97
Mr-Mike's Avatar
Mr-Mike
Originally Posted by Cygnusx51
Too late!!
See what happens when you play RUSSIAN ROULETTE LOL.
Old Apr 14, 2018 | 08:33 AM
  #98
oakmossy's Avatar
oakmossy
in hot dry climates the fluid lasts longer. So test and then decide.
Old Apr 14, 2018 | 11:25 PM
  #99
lh4x4's Avatar
lh4x4
I have 24 bikes and 11 were due this winter. However I put a small hole in the seal with a needle then reseal with tape. It is good for two years that way. Just as sealed as the master cylinder for the same time period.
I used up both 1 quart containers for the work and will buy new when next years lot comes up.
Old Apr 15, 2018 | 05:25 AM
  #100
barneyboy's Avatar
barneyboy
Thanks, that makes $en$e. Are you filling the MC with a syringe to minimize spillage?
