Solid Red Light
Old Jan 28, 2018 | 08:10 PM
H-Town's Avatar
H-Town
Default Solid Red Light
I’ve searched the forum with mixed success in this now. Found suggestions of a burned out light but that does not seem to be the issue.
2015 Street Glide Special
I have a solid red light when the bike is on. It’s tbe same flashing light for the security system but it stays on solid now. My volume control and cruise control switch are not working now either. Before I take it to the dealer, I’m hoping to see if there was any other advice this group could offer me first.
Thanks in advance.
Old Jan 28, 2018 | 08:16 PM
bad tappets's Avatar
bad tappets
Solid red security light indicates you have a trouble code (DTC). Check for codes.
Old Jan 29, 2018 | 05:30 PM
Bwpkmp's Avatar
Bwpkmp
Stage III
It's amazing how goofy the bike's instrumentation will respond with a flaky battery in the fob. If it's been a while since replacing the fob battery ..... try the simple things first.
Bruce
Old Jan 29, 2018 | 05:43 PM
cycle7447's Avatar
cycle7447
Community Influencer
Bwpkmp - who knows - you may be right. But I have to wonder if that has any effect on the vol control and cruise control.
I don't have any idea - but sounds closer to a left switch pack issue
Old Jan 29, 2018 | 06:06 PM
Iceman24's Avatar
Iceman24
H-Town; Take your bike to HD-Ville for a service check on codes...
Old Jan 29, 2018 | 06:12 PM
Bwpkmp's Avatar
Bwpkmp
Stage III
You're right .... I'm just guessing also but anytime I run into something weird in the electrical I generally suspect a ground problem or battery. Those little 2032 (IIRC) batteries are cheap. Another thing you can try is to make sure your fobs are way out of range (or remove the battery) and manually punch in the bypass code and see if everything works fine.
Bruce
Old Jan 29, 2018 | 08:39 PM
14GuineaPig's Avatar
14GuineaPig
& did you check for codes like bad tappets suggested?
Old Jan 29, 2018 | 08:42 PM
K Melancon's Avatar
K Melancon
You have codes stored. Check them
Old Jan 29, 2018 | 08:45 PM
K Melancon's Avatar
K Melancon
If you don't know how. Press and hold trip button, turn on ignition, diag will appear in odometer. What code shows? You press trip quick and it goes through each system. You should have N behind each. If you get a Y that is where it is and press longer when on that one
Old Jan 29, 2018 | 08:56 PM
Vernal's Avatar
Vernal
Let us know what codes you find
