Interesting observation
Old Mar 23, 2018 | 09:39 AM
penmaker's Avatar
penmaker
Originally Posted by silveradoman2
Is it possible that a washer or a shim was installed on both calipers causing them to be offset to one side?
I didn't see anything like that.
Old Mar 24, 2018 | 08:16 AM
Stonehaller's Avatar
Stonehaller
Stage I
You should rebuild your brake calipers and flush and change the brake fluid. Side that is worn more probably has a piston getting stuck so pad rubs on rotor when brakes are not applied and wears faster. Check your rotors for excessive wear. Inner piston is farthest from the port so fluid is more stagnate in that side allowing corrosion to build more quickly.
HDMM
Oct 12, 2012 07:55 PM
desert drifter
Oct 9, 2012 11:33 AM
RZA
Feb 10, 2012 09:21 PM
pettifogger1
Mean City Cycles
May 11, 2010 04:58 PM
AR-15 DEUCE
Mar 28, 2010 09:59 AM
