Khrome Werks 2+2 Narrow Sweepers are installed
Old Apr 21, 2018 | 11:09 AM
Happyharley's Avatar
Happyharley
FYI, There are a lot of U-tube videos out, showing how to do the swap. Take your time. I did not need to buy any wire extensions. Wires were tight but doable. Be very careful when you reinstall break and clutch housings, you don't want to pinch any wires. Don't ask how I Know.
Old Apr 21, 2018 | 03:22 PM
wenterkin's Avatar
wenterkin
Agree..easy install if you take your time and are careful. Go ahead and get a set of extended wires (not plug in extensions) and run the wires internal. Result is much cleaner look.
Old Apr 23, 2018 | 02:48 PM
SprungDave's Avatar
SprungDave
I really like them on my bike. A small, but really worthwhile investment of $100. And a little bit of your time. These are the bars the bike should have come with.
Ride Safe!
Old Apr 23, 2018 | 03:44 PM
PopsHD's Avatar
PopsHD
Had the bike out on a short 100+ mile ride yesterday. The sweepers are awesome! Money well spent, for sure.
Old Apr 24, 2018 | 09:13 AM
jfrizman's Avatar
jfrizman
Where did you get your wire extensions at?
Old Apr 24, 2018 | 07:17 PM
wenterkin's Avatar
wenterkin
Got mine from local indi. Not sure of brand, but direct plug to switch pack and harness.
Old Apr 30, 2018 | 11:58 AM
stevensousa's Avatar
stevensousa
Stage III
Did you keep the stock cables - were they long enough? Thanks for posting.. Hoping to order real soon
Old Apr 30, 2018 | 02:35 PM
PopsHD's Avatar
PopsHD
Used stock clutch and brake cables. If you plan on running wires internally, you will need TBW extension.
Old Apr 30, 2018 | 02:59 PM
stevensousa
Stage III
Great. hoping to try to do this myself this summer - I just got an 06 UG and the stock hbs are killing my back - i need to them closer .. hoping cables will reach on an 06 also. Thanks for the info.
Old Apr 30, 2018 | 05:41 PM
wenterkin's Avatar
wenterkin
Stock lines work just fine. I took some time to clip some of the zip ties and route a little more efficiently.
