Wheel bearings?
Old May 6, 2018 | 03:44 PM
steelerdude1's Avatar
steelerdude1
Default Wheel bearings?
Given all of the failures I have seen on the forum a while back, I’m curious if 2015 models have issues. If so, is it front, rear or both? I’m going to need a new front tire, and m wondering if I should get new ones put in when changing out the tire.
Doing a big trip to Sturgis and Yellowstone in August, and don’t want to have any issues.
Old May 6, 2018 | 04:16 PM
rwven's Avatar
rwven
I've got 34,000 miles on mine and I've just installed the fourth set of front wheel bearings. I'm still on the original bearings on the rear wheel. Some have higher mileage on their original front wheel bearings. It's a bit of a crap shoot.
Old May 6, 2018 | 04:46 PM
hbsoldier3's Avatar
hbsoldier3
Exactly that, I have 41,000 on my 14 FLHTK on the original bearings. I had a vibration, took it to the dealer to check the wheel bearings. They pulled both wheels, bearings were good. However, the wheels were out of balance so they rebalanced them. Took them over two hours to check everything out. Oh, and at no cost to me.
Old May 6, 2018 | 05:51 PM
PeteF's Avatar
PeteF
I’ve got nearly 24,000 on my 2016 RG. I check the bearings when I have the tires replaced. They were checked again about a month ago and they’re still good. It’s really odd that some bearings fail early and some don’t especially since the rider really has no input on bearing wear.
Old May 6, 2018 | 06:30 PM
ringer1969's Avatar
ringer1969
my fronts where done at 12,000 kms
Old May 6, 2018 | 07:56 PM
jammerx's Avatar
jammerx
I had front bearings warrantied on my bike, rear still going at 35k
Old May 7, 2018 | 06:25 AM
lp's Avatar
lp
Wheel bearings shmeal bearings, who cares, where are we meeting for our trip to Sturgis and Yellowstone?
Old May 7, 2018 | 08:12 AM
oakmossy's Avatar
oakmossy
mechanics mantra " don't fix it if its not broken". Now with let's say 40-50k miles I would replace them just for grins during a tire change.
Old May 7, 2018 | 08:28 AM
BigMike's Avatar
BigMike
I had to remove mine when I got the wheels powdered but the bike only had 5k miles. The front right bearing had rust on the outer part. I replaced them with All ***** bearings. It's an inexpensive replacement if you have the tools. I think all of the bearings were less than $60.
Old May 7, 2018 | 09:18 AM
hardheaded's Avatar
hardheaded
mine lasted 2400 miles, my brothers lasted 20,000. go figure, but i think they are junk compared to the older tapered bearings.
