Lower fairing screws
Old Nov 28, 2018 | 10:14 AM
  #31
14GuineaPig's Avatar
14GuineaPig
Take a look at the parts diagrams or the service manuals again. It looks like the 2 screws that go into those brass nuts just pass thru the Ducts, and are securing the ducts in place. It looks like the nut inserts are actually part or the Fascia Assembly, Lower Left (57100170) or Fascia Assembly. Lower Right (57100171) and those are listed as #32.49 on Ronnie's HD.
http://partsfinder.onlinemicrofiche....=54&c=0&d=2014 FLHTK ELECTRA GLIDE ULTRA LIMITED [KE] FAIRING LOWERS
Old Nov 28, 2018 | 09:17 PM
  #32
JimL_15 Electra Glide's Avatar
Well Nuts
Old Dec 1, 2018 | 07:39 AM
  #33
AFMM3's Avatar
AFMM3
My parts catalog is for 2014 and appears to be incorrect. It does not show the dashed lined going all the way to the facia. I believe your are correct.
Old Aug 11, 2019 | 05:08 PM
  #34
wparente's Avatar
wparente
What I did is drill out the heads on the torx screws. I was then able to disassemble. I then drove the brass inserts out back word. I put the brass insert in the vise and backed out the screws with a plyer. I put some super glue in the faring hole for the brass insert and drove the insert back in. I then went to Fastenll and bought new screws. The one thing I did not do was put Locktite on the screws like the factory did. All is just like new. 8/11/2019
Old Aug 12, 2019 | 05:11 AM
  #35
AFMM3's Avatar
AFMM3
When I replaced my waterpump for the new style, I had 3 out of 4 come out OK. As required by the Laws of Murphy, it was the fourth one that stripped out so as to provide maximum disappointment. I found the appropriate size EZ-Out and used it to hold the insert from the outside whilst removing the inner screw. The new pump provides great peace of mind BTW.
Old Mar 9, 2020 | 03:26 PM
  #36
William Bartsch's Avatar
William Bartsch
6th Gear
I’m planning on updating my water pump on my 2016 limited this spring and I’m going to try using a soldering iron to heat the screw and soften the loctite. Has anybody else had luck trying this?
Old Mar 11, 2020 | 11:29 AM
  #37
SEFast's Avatar
SEFast
Removed my lowers to have them Acrylic Clear Coated (Spray on Clear Bra) and had to drill out all four of those lower fairing bolts. Started small and increased drill bit size until bolts came out. Replaced them with black nut and bolt from Lowes. Not worried about the look of the nuts, since they are be covered up by radiator screen. worked perfect!
Speedy
Old Nov 30, 2020 | 12:27 AM
  #38
Alawishes's Avatar
Alawishes
1st Gear
Cool MY 2016 FLTCUSE aka Road Glide Ultra Clasic CVO
The top front of the lower fairing , the CAP FAIRING lower right or left, how does that come off after the screws are removed? I am having a hell of a time getting it to come off. I have the bottom loose and the coolant reservoir, and pressure cap loose. I don't want to break it with my big mitts.
Old Dec 25, 2020 | 04:31 PM
  #39
Reno8220's Avatar
Reno8220
I used this same tactic to get my lowers off when I replaced my water pump on a 2016 RGU. Worked like a charm. Held the soldering iron on the heads for about a minute. Be careful when you turn and loosen them as they stay hot for a while. Learned about this from another member in a post on replacing the pump. Good luck.
Old Jan 29, 2021 | 11:41 PM
  #40
Kurt Nussle's Avatar
Kurt Nussle
Stage II
drill 2 tiny holes in the brass and use snap ring pliers to hold it
