Replacement battery
Old Sep 28, 2018 | 08:02 PM
tjbennett's Avatar
tjbennett
Default Replacement battery
Has anyone used a Duracell Ultra 30LA AGM battery? I need to get a new one and was looking at one of these. Any reviews good, bad etc.?
Old Sep 28, 2018 | 10:19 PM
TXPHNDL's Avatar
TXPHNDL
I have one. No issues. Spins the motor better now than the OEM.
Old Sep 28, 2018 | 10:36 PM
AussieDog's Avatar
AussieDog
I replaced mine this summer in a 2014 FLHTK. Looked at a lot of info on the forum, Amazon, other stuff on line, and the HD website. In the end I went down to the HD dealer and bought an OEM. Quick, easy, no hassle, knew it would fit, easy warranty claim if needed. I am sure you will save some $$$ if you buy on-line, and several are available with higher CCA or Amp-hr. Make your own decision, I went with easy, reliable, and what I was confident would work.
Old Sep 29, 2018 | 08:48 AM
tjbennett's Avatar
tjbennett
I was going to go the HD route until I read all the negative reviews on their own website with the battery. So I found the Duracell Ultra 30LA AGM battery at a local Batteries Plus Bulbs store. I was also debating a ThrottleX MX30L.
Old Sep 29, 2018 | 09:25 AM
PDB17UltraRG's Avatar
PDB17UltraRG
I would go OEM myself HD stands behind there battery’s and they last a lot longer from what i see and read.
Old Sep 29, 2018 | 10:12 AM
tpcowfish's Avatar
tpcowfish
I'll probably go oem also,original battery still going good on my 14 Limited, 43,000 mi. Must not be to bad
Old Oct 1, 2018 | 02:18 PM
hardheaded's Avatar
hardheaded
Why not the Big Crank from Battery Mart for $112.00 delivered to your door ? Got one coming so i will see how it does.
Old Oct 1, 2018 | 02:26 PM
Blue Tick's Avatar
Blue Tick
FIL bought one of these to put in the MIL's trike a while back and it works great. I'm getting ready to do a replacement on my '16 Limited and this will be the one I go with. He got his at the local batteries plus also. I don't remember the price, but I do know hearing her's start it seems to turn the bike over a lot easier/smoother than the oem's do.
Old Oct 1, 2018 | 04:09 PM
Joe Promedio's Avatar
Joe Promedio
Stage II
Default Battery replacement
I am looking for a new battery also. I bought my first battery, since new, 26 months ago for my 07 Dyna from H/D. It is now showing signs that it is not keeping a charge and is slow starting. I tested it and it shows to the weak side. The battery that came with the bike lasted 7 years. So I am looking for something else. I will watch this thread. I will also let you know what I decide and why.
Old Oct 1, 2018 | 09:56 PM
hardheaded's Avatar
hardheaded
I thought the deka big crank was the same battery as the duracell ? At least i thought they were made by the same company.
