Kill Switch Issues
Old Jul 14, 2019 | 07:44 PM
cycle7447's Avatar
cycle7447
Community Influencer
Must be a matter of choice. Each time I prepare to turn the bike off, I simply reach for the kill switch. This way, I can keep my hands on the bars. I pull in, clutch in and hit the switch.
I am with others - could be the fob.
Try this, turn the ignition on, hit the kill switch and see what happens. Do you hear and noise. EFI should activate. If not, see if there is anything (Like enter PIN) on your screen.
Good luck
Old Jul 14, 2019 | 07:56 PM
RANGER73's Avatar
RANGER73
I don't know if you have one but my little ice cube start relay needs replacing every few years.
Old Jul 17, 2019 | 02:54 PM
Cygnusx51's Avatar
Cygnusx51
On my ‘16 RGS, the kill switch stopped shutting the engine down but allowed it to start thankfully. Got the switch pack replaced and there’s been no issues since.
Old Jul 20, 2019 | 07:55 AM
oakmossy's Avatar
oakmossy
i use kill switch to kill engine, for me thats best, when it fails I will replace.
Old Jul 20, 2019 | 11:23 AM
Michael Haz's Avatar
Michael Haz
OP here. I had my HD dealer check the kill switch issue while they were performing the 20,000 services. The cause of the problem was loose terminals at the switch pack. They were tightened and the switch now operates normally.
Old Jul 21, 2019 | 01:09 AM
brokefootkenny's Avatar
brokefootkenny
i was told when i bought my bike to always use the kill switch to shut bike down. never had an issue.
Old Jul 23, 2019 | 09:18 AM
TriDan's Avatar
TriDan
CVOs turn **** only has lock and unlock (for front forks) on them. Only the kill switch to stop the engine of the bike. Can't imagine how that's something to be avoided.
Old Jul 23, 2019 | 09:26 AM
TriDan's Avatar
TriDan
Originally Posted by target64
It is my opinion that the kill switch is only used in the case of and emergency, I turn the main switch on and off to start any bike. the kill switch is going to get worn contacts with all that use and is going to fail at some point in time. just my two cents!
Here's my and my buddy's center switches. I would appreciate it if you would show me how to shut my bike off without using the kill switch, please. Maybe put it in gear and stall the thing every time? I'm guessing that would be worse on the machine than using the kill switch.
Before anyone says anything about "updated switches" or some nonsense, I had to replace the left switchset because the up/down XM station wouldn't switch channels and it's exactly the same switchset as anyone else with one except mine comes with backlighting from the factory.
Old Jul 24, 2019 | 02:11 PM
target64's Avatar
target64
the cvo's only use that switch for a fork lock,but the cvo's are the only bikes which use that switch as just a fork lock. all others its the ignition switch which supplies power for all functions. your bike is set up different it uses the kill switch to turn on and off power to the bike. so yes you have to use your kill switch.
Old Jul 24, 2019 | 03:17 PM
Magnut1's Avatar
Magnut1
When my fob battery was nearly drained, it would do the exact thing, Sometimes it would recognize, sometimes not. I brought my other fob in and it worked fine. You could use a volt meter to measure fob battery voltage.
