Fork tubes
Old Jun 21, 2020 | 05:58 AM
Drtumolo's Avatar
Drtumolo
Default Fork tubes
I ordered a set of Howard's 30mm cartridge's and to minimize down time I am looking for a set of OEM fork tubes for my 2016 streetglide to have machined in advance. The OEM part number is 45500113. I can find aftermarket tubes cheap but thought I would ask if anyone has a set of OEM ones they want to get rid of?
Old Jun 21, 2020 | 09:57 AM
chopper_man's Avatar
chopper_man
Curious, been considering these myself. Was not aware any machining was needed, thought they were drop-in. Howard's site says can be done at home with simple hand tools. What needs to be machined?
Old Jun 21, 2020 | 07:54 PM
Drtumolo's Avatar
Drtumolo
The 30mm requires some minor machine work. I don't have all the details on what needs to be done but I know it is minimal. I figure once I am ready to take tubes to the machine shop I would call Howard for the details on what needs to be done. Your best to contact Howard. He has all the details.
Old Jun 21, 2020 | 08:32 PM
GalvTexGuy's Avatar
GalvTexGuy
Just guessing, but Howard’s kit probably requires boring two more holes in each stock dampening rod. Go to 4:03 in the video and you’ll see the Pro Action kit’s dampening rods and the extra holes. Pro Action’s kit comes with new dampening rods so you don’t need to bore additional holes in your stock ones.
Old Jun 21, 2020 | 08:37 PM
Drtumolo's Avatar
Drtumolo
no it is a ohlins cartridge kit not a rework of dampers.
Old Jun 21, 2020 | 08:50 PM
GalvTexGuy's Avatar
GalvTexGuy
Oops, my bad. So, the actual lower fork tubes have to be modified? That’s the first I’ve heard having to have lower forks machined for a suspension upgrade. Weird...
Old Jun 21, 2020 | 09:56 PM
chopper_man
Exactly. Even Howard's website says "This modification can be done at home with simple hand tools and a oil measuring device. No more running to have someone else do your work." Sure doesn't sound like machine shop needed by that statement.
Old Jun 21, 2020 | 10:22 PM
Uncle 'B''s Avatar
Uncle 'B'
It's the upper end of the fork leg, where the fork cap screws into the fork leg, that needs to be shortened about 0.130"~0.150".
The threads on the Ohlins cap start about an 1/8"~3/16" higher than the stock Harley fork caps.
When you screw the Ohlins fork cap into the top of the stock fork leg, it only grabs one or two threads before seating on the top of the fork leg.
Because of that, you need to trim (or deck, if you will) a little bit off the top of the fork leg so that the cap gets full thread engagement.
When I did mine, I needed to turn 0.135" off one leg and 0.150" off of the other because of Harley's manufacturing tolerances.
No matter how nice it is, your favorite #3 throwing hatchet isn't the tool of choice for this operation.
This is a quick "no brainer" task for a machinist, but he can't do it in advance without having the caps in hand.
Hope that all made sense.
Bryan
Old Jun 22, 2020 | 04:22 AM
Drtumolo's Avatar
Drtumolo
Ok thanks for the info Uncle B. I was unaware that I couldnt do the mods in advance. thanks for clearing that up
Old Jun 22, 2020 | 04:15 PM
hattitude's Avatar
hattitude
I'm not a machinist, so forgive my probable stupid question....
Can't you just have a machinist trim 0.150" off both tubes, without the caps, ahead of time.....?
