Tpms
Triger-man has extensive Info on this, he includes in his post all part numbers needed to complete this upgrade, well worth the investment for those that want TPMS.
Search Trigger-man post.
If you don't have a CVO, where does a warning show up at for low tire pressure (as far as I knew a CVO tach is required for the dummy light for TPMS)?
Does an alert automatically pop up on the stereo?
I thought I'd read that post and BCMs had to be switched out on all non-CVOs... I'd like to be wrong lol
Thanks for the info.
Much like the car play hack that was happening there for a bit on the GTS, with no WHIM. Dealers would flash the radio so car play would work, then all of a sudden. They wouldn't do it anymore unless you had the WHIM.
just reading these forums there are some dealers who simply wont do anything that's not in the box. If your bike didn't come with it or you didn't buy it. we ain't doing it..... sad, but apparently happens a lot.
There is an after market device like the Digi-tech ( name escapes me ) but any Indy that has this can Flash and enable the TPMS option for you, they can also flash your BCM or replacement BCM.
Had mine done at Pocono Mountain HD your local dealer can call Brian Service Manager for Information if needed.
