103 High Oitput mods
Old Jul 10, 2022 | 08:33 AM
Crashrdking01's Avatar
Crashrdking01
Originally Posted by rigidthumper
Check with V&H about available maps for the cam choices- I 've had a couple that we had to go to a flash tuner (TTS/PV/DL) to achieve decent results.
thx...
Old Jul 10, 2022 | 08:52 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Crashrdking01
Just wondering what kind of mods anyone has done to their 103ho? All I have done Isa set of open fishtail exhaust..and there is a smallplate in it for backpressure..I still have my cat ...
Food for thought :> there is a smallplate in it for backpressure.
Old Jul 11, 2022 | 01:41 PM
SammySRT8's Avatar
SammySRT8
Stage II
I modded my 103 HO, by removing it from my '16 Ultra Classic and replacing it with a 124" S&S from Fuelmoto...
Hey, I was going to change the air cleaner anyways, so I thought what the hell....
Hey man that looks flawless!! Couple of quick questions:
  1. What did you do about the liquid cooling? Did you delete it?
  2. What other parts did you have to buy?
  3. Any gotchas during the install?
I have a 2016 Ultra and I'm on the fence on buying a whole new bike or do what you did.
Thanks!
Old Jul 11, 2022 | 02:51 PM
Crashrdking01
https://www.youtube.com/watch?v=jjPeP_Nn2B4
thx ...yes I figured that...plus I'm thinking the cat helps with the back pressure too...but i could be wrong
Old Jul 11, 2022 | 07:24 PM
hattitude's Avatar
hattitude
Thanks!
I purposely bought a '16 Ultra Classic- air cooled- because I knew I wanted to put a FuelMoto crate engine in it... I didn't have to deal with water cooling.
In addition to the crate engine, I also bought: exhaust system, 58mm throttle body, 5.3g/s injectors, Stage II air cleaner, S&S oil line kit, AIM variable pressure plate, Barnett heavy clutch spring, Muller hydraulic clutch slave cylinder, Twin Power solid engine sprocket, assorted gaskets and fluid, and had it dyno tuned... I already had the PowerVision tuner
I was prepared to swap it out myself. It's not that hard if you follow the service manual and other instructions....
But since I was buying the crate engine from FuelMoto, and wanted Jaime to tune it, along with issues getting performance parts shipped into CA, I just trailered the bike there and had them do the engine install... they're installation, dyno break-in, and dyno tune price was very, very good.... I added the muller slave cylinder and Twin Power solid engine sprocket when I got it home..
I ended up 125HP & 151TQ...
Old Jul 11, 2022 | 07:27 PM
SammySRT8's Avatar
SammySRT8
Stage II
In addition to the crate engine, I also bought: exhaust system, 58mm throttle body, 5.3g/s injectors, Stage II air cleaner, S&S oil line kit, AIM variable pressure plate, Barnett heavy clutch spring, Muller hydraulic clutch slave cylinder, assorted gaskets and fluid, and had it dyno tuned... I already had the PowerVision tuner
There were no gotchas... I was prepared to swap it out myself, but since I was buying the crate engine from FuelMoto, and wanted Jaime to tune it, along with issues getting performance parts shipped into CA, I just trailered the bike there and had them do the install... they're installation, dyno break-in, and dyno tune price was very, very good....
Awesome man and I appreciate all the info!
Have a great day and stay safe out there.
taube0dahkota@gmail.com
Aug 16, 2020 06:56 PM
Bluehighways
Jan 28, 2019 10:44 PM
maverickwolfe
Touring Parts
Oct 13, 2017 08:48 PM
NMNSG08
Oct 30, 2012 11:17 PM
