Cutting out pushrods
Old Nov 10, 2022 | 03:30 PM
harley7316's Avatar
harley7316
Default Cutting out pushrods
Going to do my cam this winter and been watching vids.All the vids they say pushrods have to be on base circle to cut them out.They find base by rotating rear wheel and watch the opposite cylinder when the pushrods start moving at the same time they cut the oppposite pushrods out.Would it not be faster just to take cam chest cover off since you have to anyway and when the the 2 dots on the gears are facing each other cut the rear and then rotate the rear wheel till the cam gear dot is 180 degrees from the crank gear dot then do the front?
Old Nov 10, 2022 | 03:47 PM
brakeless's Avatar
brakeless
Not hard to do really. Just watch the pushrods. When one is unloaded in the lowest position cut it.
Old Nov 10, 2022 | 03:58 PM
Sam2010's Avatar
Sam2010
Don't overlink it. I was the same way first time I took cam cover off peaked inside Mark the straw down the spark plug hole. Second and third time rotated the wheel watch them and cut them out and keep on trucking.
Old Nov 10, 2022 | 08:49 PM
lp's Avatar
lp
A M8 but same concept:
Old Nov 11, 2022 | 06:39 AM
Architect's Avatar
Architect
Winter project? Spend the time and take the rocker boxes off and remove the push rods. When done, reinstall. No reason to add an adjustment to an under complicated part of the motorcycle. Plus I am sure there is lots of crud under your tank/top of the boxes that you can spend time polishing, everyone has it. I am just not a fan of adding an adjustable part when a fixed part works just fine, but I need to spend a couple of extra hours getting to it. My 2 cents, good luck with the project.
Old Nov 11, 2022 | 09:21 AM
harley7316's Avatar
harley7316
Thanks for the replies.Just getting Carpel tunnel surgery so will do this over a weekend in the New Year.
Old Nov 11, 2022 | 09:52 AM
hattitude's Avatar
hattitude
Around 2010ish, when labor rates were cheaper, it was the about same cost to pay to have a tech go through the top and reuse the OEM pushrods (on a cam with the same base circle as OEM) than to cut the OEM pushrods and pay for the adjustable pushrods...
I prefer having solid, one-piece pushrods too..... I even had custom, one-piece push rods made by Smith Brothers for one of my bikes.
On my bike that I switched to adjustable pushrods, I didn't cut the OEM pushrods. I still took the fuel tank & rocker covers off to remove the OEM pushrods... I just never found going through the top daunting or overly time consuming.... Plus, I like inspecting the rockers/breathers while I'm in there...
But to be fair to all the techs out there who cut them, when I'm working on my bikes it's kind of a hobby... I'm not "on the clock" .....
Old Nov 11, 2022 | 10:05 AM
brakeless's Avatar
brakeless
I tend to be a bit shy when it comes to cracking something open when there's really no need. Murphy's Law runs rampant in my garage! LOL!
If it works, it don't need fixin! There's nothing wrong with adjustable pushrods.
Old Nov 11, 2022 | 10:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Yes, since the cam cover is coming off anyway, that is the easiest way to determine when the cam is on the base circle.
Not a fan of adjustable pushrods, especially on an engine with hydraulic lifters, I had 2 of them come loose on my Evo (one time I was lucky, the second time it cost me a lifter).
Old Nov 11, 2022 | 10:19 AM
WONKEY's Avatar
WONKEY
When I had to replace my lifters on my 2014 SGS I cut the OEM push rods out and installed adjustables, if I have to do it again I will go thru the top and reuse the OEM push rods. I would also install rocker lockers while I had ti apart.
