Check Engine Light
Old Apr 18, 2023 | 09:59 PM
Black Ultra's Avatar
Black Ultra
Default Check Engine Light
So, I installed my new bars today. Process seemed to go smooth, they fit great and much more comfortable. I checked all the functions of both side controls and all is well. The bike runs fine. I took a quick spin around the block and noticed the check engine light is on. I don't have a scanner. Is there a way to check codes without one? Any ideas what might be going on?
Old Apr 18, 2023 | 10:27 PM
Hulkss's Avatar
Hulkss
Just hold down the button for the trip odometer and turn on the ignition to get into diagnostic mode. Plenty of how-to videos on You Tube detail how to go through the whole process.
Old Apr 18, 2023 | 10:28 PM
hattitude's Avatar
hattitude
Yes there is......
I don't own an M8, so I don't know if the process changed for them, or for the new ECM introduced around 2021...
Someone will surely post up soon with the M8 procedure....
NOTE: Hulkss and I were typing at the same time....
Old Apr 18, 2023 | 10:54 PM
Black Ultra
Thank you guys! I found a video on how to read codes. I found the following:
ECM
P2122h, P2127h
BCM
C0077h, b2106h, b2141h, b2146h
SPDO
U0141h
I also found a video on how to clear codes. I cleared them all and now I have no check engine light!
Old Apr 19, 2023 | 09:35 AM
hattitude's Avatar
hattitude
ECM
P2122h, P2127h
BCM
SPDO
U0141h
Glad you got it figured out...
Just for info, those are all historical codes as designated by the "h" at the end...
After a certain number of engine cycles, they would have cleared on their own unless they became current again... but it's always better to be able to control them...
Old Apr 19, 2023 | 10:53 AM
Black Ultra
Thanks for the clarification, I was wondering why "h" didn't appear when I searched the codes to see what they were for.
Old Apr 19, 2023 | 01:18 PM
rideonva's Avatar
rideonva
As already been mentioned all codes are historical (might have been triggered when you were disconnecting/reconnecting stuff). Try to clear them (hold trigger button while in code display mode and answer yes to clear specific module codes, continue to next module) and see if any codes come back.
Old Apr 19, 2023 | 01:29 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Did you happen to remove the maxi fuse before you started?
The hand controls have modules that are always powered along with the BCM and ECM. It could be if you removed wires during the bar change the BCM saw them as errors.
Old Apr 19, 2023 | 02:22 PM
Black Ultra
No I did not pull the main fuse. I agree, the vast majority of the codes were related to things I unplugged and plugged back in. I didn't see any requirement to pull the fuse in the service manual, but I may have missed it. Also, the "How To" videos I watched did not pull the fuse. Not saying they did it right, just saying.
Old Apr 19, 2023 | 03:13 PM
JamesGilbertAZ's Avatar
JamesGilbertAZ
I pull it anytime I do work... just because. Don't know if that is a bad habit, but I have never had any codes.
