Need a good starting point
Old Aug 4, 2023 | 10:00 PM
Tazzman's Avatar
Tazzman
Default Need a good starting point
Installed V&H power duals, Crusher slip ons, RSD high flow airbox, S&S oil pump and cam support plate, Woods Night Prowler 222 cam, SE adjustable pushrods, and a Thundermax in my 2019 FLHTK with a M8 114 in it.
Started with a Stock map for 2:1:2 and bike ran wonky for the first 20 or so miles and started dialing in. Issue I have is when I ride a while and she gets hot the idle will stick between 2.5-3.5k for around 15-30 seconds before it settles down to the 1000ish I have it set to. This is pretty hairy when I'm down shifting to slow her down.
Wondering if there's a setting I'm missing? I did look at the idle vs temp setting and it reads 1024 rpm across the board.
I'm baffled.
Old Aug 7, 2023 | 03:34 PM
dmonger's Avatar
dmonger
Get a real tune on it.
Old Aug 8, 2023 | 06:06 AM
LazySundays's Avatar
LazySundays
Your ECM ID making assumptions for engine load, cam timing and cylinder fill based on a baseline that has changed due to the cam change. You either need to find a base map for your combination or take it to a good tuner.
I would not ride it with the current MAP
SoCaRider
Milwaukee Eight (M8)
Sep 19, 2020 03:46 PM
gaslog4
May 28, 2016 08:07 AM
Dsrt
Engine Mechanical Topics
Dec 12, 2014 05:48 PM
Kbore
Exhaust System Topics
Apr 13, 2009 09:59 PM
Jameson
EVO
May 17, 2007 07:35 PM
